3in suspension
04runnerSR5
i have a 2in cornfed spacer on the front of a 2004, but i want to upgrade to a 3in suspension on the front. Does anyone recommend any good ones that are not to expensive?
you can try the toytec 3in. but that much on just the front without doing at least an 1in. out back might put you a bit nose high, you can get adj. COs & set it where ever ya want, but thats alot more $.
get FJ springs all around. It'll give you 1/2-3/4" in the front and 1/4"-1/2" in the rear. Not quite 3" but closer and cheap!
he s got a good idea, if your on a tight budget, you can pick them up at a decent price, get a better ride, & save some more $ if ya do it yourself. but if you rather have spacers, check out the thread on the discount code for the toytec site. then again ,i think you can get just the daystar 2.5 front spacer for around 50 bucks. cornfed will cost alot more but they do have a 3 inch set.
x3. Gaberelli and Chaz got it right... Very high bang for your buck and with your current 2" spacer you'll be close to 3" and it'll drive much better.
:cheers:
personally, id go with the bilstein adj. 5100 strut over the rancho. i think bilsteins have a better street ride than the rancho products. & they cost less.
delislerebecca
