Trip_84
Check with Chris @ Nisstec or Corey [MENTION=116638]InSainFab[/MENTION]. Their labor prices are very reasonable and they are very experienced in installing lifts.
Hey thanks alot i will check with them for sure!
Average shop charges about 100 bucks an hour. If I as a mechanic make 20 bucks an hour, your saying I should do it for 2 hours pay-or 40 bucks? No thanks.Yes. A shop should charge no more than $200 to swap out shocks and coils all around.
Thanks for the info. Talked to one place last week and they were talking like $85 an hour 5-6 hour job. Seemed a lot. 4Wheel parts guy in denver estimated about $500-$600 to do it and said that includes the $160 alignment. Brakes Plus is doing alignments for like $58 right now so.
Might just make an add on craigslist to see if anyone wants to make an extra $300 when im ready to have the lift put on, then just take an get alignment from somewhere that wont crack my wallet open
So your saying that if I give u 40 bucks you'll install new coils, struts and shocks all around on a truck that's 20 years old? And use all your own tools that you shelled out money for?Well two things...you over charge your clients or my shop has a better deals. Doesn't take that long for a shop to swap out those parts.
Just installed my OME lift... went with the 881/906 combo plus I put in some 10mm spacers in the rear as I wasnt sure if the 906's would be tall enough to have it sit right. I prefer the rear to sit half an inch higher than the front, giving it an aggressive stance without obvious forward rake. I went with the usual 90004 shocks in the front but decided to go with the newer 60073 soft shocks in the rear as Ive hear many complaints about the 906/60028 combo being too stiff.
I have to say for me, it sits perfectly, and the ride is amazing. Feels so much more planted than with the stock suspension. The rear end doesnt bounce around like an old Cadillac now. Definitely firm and responsive but not rough, still absorbs the small bumps. It seems to corner about the same as before, given the suspension is tighter, but the truck sits higher up. I havent measured the difference in height yet but, being a 2000, it had the lowrider springs on it so the difference is pretty noticable for me. Ill post some pics for anyone who is wondering about this lift. Id definitely recommend the 60073 softer shocks with the 906's. I wouldnt want it any more stiff but it is perfect the way it is now, mind you I dont carry a lot of weight around in the back. Tires are 265/75R16 FYI.
And just to give anyone an idea of the angle of the control arms
If anyone has any questions ask away. I know when I was deciding on the lift I had a zillion questions and had a hard time pulling the trigger.
Looks awesome man! Looking forward to some measurements. When you do, please include center of hub to bottom of fender.
Also what made you choose 881 over 880?
BUMP! Been a couple days. can i get some help here?
