3rd Gen 4Runner SR5 Front MudFlaps bolt size?
la79
Hey everyone, does anyone know the bolt size, thread, length for the black SR5 front plastic mudflaps? These mudflaps were made by AMP industries and were discontinued a long time ago.
The original part numbers were:
PT41335966DF
PT41335966PF
Seems that a bolt comes included with the original kit to screw into the body. I've attached a picture here of what the original kits come with. If you look at the picture there is a long skinny bolt in the photo. For anyone who currently has these would you be able to share the size?
I bought the stock Toyota fronts (75$), they used 10 mm (x3) bolts and a rivet to mount on. They looked identical to these ones (these probably work but they are for Tacomas). There wasn't a long skinny bolt in the OEM kit, they were all like the ones I linked above.
PT41335966DF
PT41335966PF
That long one is supposed to go UP through the bottom fender bolt I believe.
Thanks for your help on this. Those are fender bolts that are used but are longer.
The normal lower fender bolts are size m6 x 1 bolts about 1inch long. Original Toyota Part number is 90119-06394
However, the bolts needed for the mudflaps has to be longer as it goes through the mud flap AND attaches to through the lower fender.
I sourced some M6 x 1 bolts about 1.5 inches long with washers and they worked fine.
However, my original fender bolts were so rusted it out that they snapped when trying to remove them :wow:
So I had to drill them out and retap. What a pain that was.
