3rd gen Aftermarket wheel thread
How much of a lift do you have? This the exact wheel/tire size and height I'm after. Thanks.
Member [MENTION=89230]GentryGoon[/MENTION]
SCS F-5 in Matte Jet Black
16x8
4.5" Backspacing
Hub-centric
19lbs.
Will clear Tundra calipers.
285/75/16 tires.
F5_WillG_R2-5.jpg~original
F5_WillG_R2-4.jpg~original
F5_WillG_R2-6.jpg~original
F5_WillG_R2.jpg~original
Wheels:
Fuel Shok Anthracite
17x10” offset -18
Tires:
BFG MT 285/70/17
Suspension:
Toytec 1” body lift
Toytec ultimate 3” coilovers
Rub:
Minimal edge of front bumper on full clock reverse. No rub on mud flaps. No BMC necessary.
Fix:
Trim 1 cm off bottom of front bumper within the fender.
I've seen these on a few 3rd gens but most seem to have at least 1.5-2" of lift. Would they fit with without rubbing at stock ride height?
Hey im looking at getting wheels for my 4runner but can't figure out if they will fit. No info on here about them fitting 3rd gen 4runners
Black rhino stadium rims
6x5.5 lug
16x8
-10 offset
4.11 BS
I'm looking for rims that DONT need spacers to clear brakes, AND give a little poke from fender for more aggressive look. Would these fit that bill? Any help or point in right direction will be apprieated
Just got my 4runnner
Been looking at getting new wheels for my 3rd gen. Has some interesting Ford OEM wheels (only what I was told. Have not taken them off to look yet) but they are 15s and I've been looking at getting 17s so I can do the Tundra 231mm caliper and rotor upgrade for the brakes. Being able to see the wheels on my model before buying is such a big help. I'll post when my new ones come in!
Currently running Vision Soft 8 wheels, 16x8 4.0"BS and unfortunately I had to trim my calipers to get em to fit. I remember seeing reviews saying they fit 3rd gen 4runners, but I forgot Sports had bigger calipers and didn't realize it until installation. Gonna need replaced eventually if I want to do the TBU, and new brakes are definitely in order
Definitely like some of the options I see in here.
Shitty pic but all I have right now
6x5.5 lug
16x8
-10 offset
4.11 BS
In case you're still curious, yes, they should work (can't comment on TBU, though). I just put on 16x8 -10 Level 8 MK6's with 285/75R16 Wildpeaks and they have slight rubbing in reverse, but I just need to trim a little from what I already did for my old 32's.
Looks great to me. I'll see if my buddy would like it for his incoming 4Runner project. We'll work on it after we finished installing the shocks and toyo all terrain tire on the current Wrangler project. Wildpeaks looks good as well.
Wheels:
17X8.5 (6mm) Fuel D557 Anza Matte Black w/ Anthracite Ring
Tires:
BFG KM3 MT
285/70R17
Suspension:
Toytec AlumaSeries 3" w/ SPC UCA
Rub:
After some minor trimming, I don't experience any rub
<a href="https://imgur.com/FnMV8B9"><img src="https://i.imgur.com/FnMV8B9l.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/WoNX7S8"><img src="https://i.imgur.com/WoNX7S8l.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/zLGKyDX"><img src="https://i.imgur.com/zLGKyDXl.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/hZIJY3w"><img src="https://i.imgur.com/hZIJY3wl.jpg?1" title="source: imgur.com" /></a>
they fit I'm running those on mine
Those are JBA UCAs I see, right? If so, caster out your wheels some, they're made to increase the amount of caster from stock (but with a stock bumper you're just gonna start rubbing the other way before you fully utilize this amount)
I too have Widepeaks and I when I did have my stock bumper I just so happened to get right in the sweet spot with my first alignment to where there was nothing at all, but after I took it in for another suddenly I had rubbing in reverse as well - usually worse on one side. Going off road it's only gonna get worse with flex
Also, very slick wheels. Really like that color.
Thanks for the info! They definitely rub in reverse (moreso on the drivers side), but I have a 1/4" strut spacer that I'm about to put in the hopes that it'll give it the clearance it needs. It also rubs slightly when fully locked to one side, so fingers crossed!
Can't believe there's been 9 pages and almost 8 years of this thread without a good ole rattle can rim special! I guess I have to represent the "too poor to get new wheels but still want to look cool" community and show mine here...
iron-duke-albums-iron-duke-s-99-4runner-picture59381-matte-black-wheels-red-toyota-masked-off-bolts-11-2-20-a.jpg
iron-duke-albums-iron-duke-s-99-4runner-picture59402-sr5-trim-removed-painted-rims-fogged-tail-lights-all-together-11-9-20-a.jpg
Probably because this is the "aftermarket" wheel thread.
Is there a list of wheel manufactures that fit our 3rd Gens? I’ve searched and this is the only thread I could find with the pretty good specs on wheels...
One thing I’m seeing is the lack of offset mention with the wheel/tire specs.
I like the deep dish look and have seen some -18 offset which might be more than I am looking for but some where between -10 to -15 offset.
If you run that kind of offset on 17” wheel will those work with the TBU? I may do that In the future and don’t want to have to buy new wheels when that time comes.
Thanks in advance!
SCS BR6
Stealth blue finish
17x9” offset -38
BFG MT KM3
285/70/17
D'Angelo
