3rd Gen Hella DE Fogs+Brackets. Seattle, WA $130
sogoood
$sold
Hella Micro DE kit with brackets. Designed for fat lip 3rd gen bumpers. Dealer option. Better light output than the bottom bulb mounted Koito factory option.
Works great!
No wire harness. Few rock chips. Surface rust forming on brackets.
Any pics of the output? I want to compare with the stock fogs I have, if significant, IM IN! Thanks
i have pics of the light output somewhere on my computer. ill tag you when i find them but it might take a bit haha.
no comparison pics since i dont have the koitos on hand. =P. sry!
edit; i think i deleted the pictures off my computer haha. ill wire these bad boys up again and update you
This may be an interesting thing to retrofit to my 96 bumper somehow. Where can I source the wiring harness for the fogs?
I have some PIAA connectors i can throw in but itll need extended wires soldered. not sure where to buy the toyota oem connectors for a decent price.
Id go with a deutsch connector if you want the best type of connector
Pictures taken with one Hella DE. Distance from shop is about 1 1/2 car length. The width of the beam couldn't be captured from that distance so it is seen diagonally.
Hellas ribbed/fluted design gives a wider beam pattern like the Rigid Ind DOT fogs, Koitos aren't fluted. Internally there is a cutoff shield. The light intensity depends on what bulbs you have. The bulbs included are PIAA 55w High Intensity. The body is designed for 55w bulbs and can also withstand heat from hid bulbs if you want to retrofit.
tobasko556
