thirstyturtle
Will do, it leans from the front and back so I'll get measurements too.Pic from the front too.
Ya that's what I'm worried about. I suppose it's possible a spring could've popped out of a seat but it hasn't been off road since the change and I can't imagine flexing enough on pavement for that to happen.Perfect, What's also really weird is you said it wasn't like this when you first put them in. Could the rear springs have popped out of their seat? If not then something must be broken, bent, or those Moog springs REALLY suck, as someone else mentioned.
I thought I read on here somewhere that the lean was mostly due to the panhard bar after a lift?
Anyway, I have a pretty noticeable lean as well. I'm pretty sure it's at least 1" difference.
do the left and right springs have part numbers?
I had OME 881F/890R springs installed in 2013. From the beginning, there was a slight but noticeable lean. I haven't measured it, but I'd guess it was about 1/2 to 3/4" down on the driver's side. 10.5 years later, the lean is the same. It's imperceptible while driving or sitting in the vehicle. And, yes...I stack heavy stuff on the right side if it's going to be in the truck for a week, like on a camping trip.Old What are you guys doing about the driver side lean front and rear? I’m on stock suspension, thanks!
