3Rd gen offroad toolkit. What do you bring?
I keep all my tools in a medium sized toolbag from Home Depot. It is portable and when I zip it shut and tie it down in the back it doesn't make very much noise. If I wanted to quiet it even farther I would throw a t-shirt in with the tools and zip it shut.
^^ This, if you want a quieter ride, this would get my vote. I have an toolbag stuffed full of wrenches, sockets, etc. in my 80 and I have had it on several rides and you would never even know it is in the back. Just strap it down good.
I just have one of those toolbox kits that comes with a full set of English and metric wreches, sockets, screw drivers, Allen heads, etc. Then I have a a big box with all the other stuff, and that has a lot of electrical equipment. Since I dont have a shop at school, my truck has to be my portable shop so I just throw everything in there.
i made the drawer storage and have all my stuff organized in there somehow. still need some of the stuff on the for the tough emergencies. so far i have a tow straps rope an emergency bag small tool bag filled with hand tools zip ties tape wire and miscellaneous tools and wires and fuses. along with a ratchet and socket tool set. still want to get an extra axle along with the sockets for that. and other essentials.
In my old ZJ I used to carry a full tool chest, a cordless drill, air tools, a jackstand, hi-lift jack, and a bunch of other things. This was in addition to spare parts and fluids. Unfortunately I ended up using almost all of these during various breakdowns on and off the trail.
One of the main reasons I purchased the 4runner was Toyota's reputation for reliability. Now I carry what I consider to be a minimal tool set for off road driving, and so far it has worked out well. Pretty much everything I carry is metric. If I have to help someone else there is almost always a metric size close enough to SAE to work, for example 13mm = 1/2". Also, since these tools are always in the truck and could possibly be stolen, most of them are inexpensive (but decent quality) or tools I've since upgraded, the good stuff stays at home. Everything is stored in a tool bag which is very space efficient and keeps rattling to a minimum. As I do normal maintenance on the truck I've been trying to make sure I could do the task with what is in this kit, but I'm sure I'm missing something and I am definitely open to input on other things to add.
Here are the tools I carry:
- Gloves (mechanics and nitrile)
- Eye protection
- Flare wrenches
- 8/10/12/13/14/15/16/17/19/21/32 mm combination wrenches. The 32mm was $6 and is great for using as a breaker bar on other wrenches.
- Adjustable wrench that opens far enough to fit on the nuts of the SS adjustable rear track bar.
- 1/2" extending ratchet from Harbor Freight (this thing is great)
- 3/8" composite ratchet from HF (surprisingly good quality)
- 8-22mm shallow Craftsman sockets on a rail (not shown in pictures below)
- 10-24?mm deep HF sockets in a box
- Spark plug socket
- Axle nut socket
- Various 3/8" extensions
- 1/4 - 3/8 - 1/2 adapters
- Hex wrenches
- Terminal crimper
- Various pliers
- Multi bladed screwdriver
- Large flat heat driver, useful as a small prybar.
- Utility knife
- 10mm hex socket
- DMM
Between the shallow and deep sockets I should have pretty much every size covered. I'm a little concerned that the 3/8" extensions wouldn't hold up to a lot of torque from the 1/2" ratchet (using the adapters) so I might throw in a 3" 1/2" drive extension since I find myself using those quite frequently.
In addition to the above I also carry a small amount of "fix it" gear including:
- Large zip ties
- Tire patch kit + extra valve stems and cores
- Spare fuses
- Spare relay
- Spare headlight bulbs
- Spare sparkplugs
- Bailing wire
- Metal strapping
- 16g and 12g wire
- Various crimp connectors
- Duct tape
- Electrical tape
- Teflon tape
- Hose clamps
Other general stuff I always carry:
- Headlamp
- Tarp
- Paper towels
- Fire extinguisher
- Air compressor (MV50)
- Air hoses and tire chucks.
- Prybar
- Ratchet straps
- Bungee cords
A broken truck is just one way you can get stuck on the trail. Having recovery options is also important.
Recovery Gear
- Factory bottle jack (someone else in our group always has a hi-lift)
- Jumper cables
- Recovery strap
- Front and rear tow points.
- Warn M8000 winch w/ 85' of 3/8" rope
- Snatch block
- Tree saver
- 2x shackles
In the future I will likely add:
- Plywood base plate for the stock jack.
- 2qt of oil
- Small hacksaw (very useful for cutting off exhaust pipes when they pinch shut)
- Spares: fuel filter, belts, hoses (only on long trips)
Ok, so this post got way longer than I intended. Here are a few pictures to make it worthwhile.
Wrenches
Most of the rest of the kit (shallow sockets not shown)
This all fits in a 12" tool bag which takes up very little space in my cargo drawer along with the recovery equipment.
The "fix it" kit goes in a box under the driver's seat.
- Matt
Bump!
Took another trip this weekend doing a little exploring and off roading on state forest trails. Not terribly difficult but all I had was my toolbox.
Would like to hear what spares fluids etc everyone is carrying.
Good .45 ACP (usually Sig P220R) and plenty of extra magazines. Backup gun (usually a little .38 snubnose). Two Benchmade Strykers, one standard and one auto. And a cell phone.
Sorry, my tool kit may be a little different than most.
Wow, where are you off-roading?!
I'd have a hard time replacing a u-joint with a .45 ....
Yeah, force of habit over the years. My actual offroading tools needs some work. I have a cheapo set of sockets and stuff that I have, but I need to work on picking up some recovery equipment.
I just did the diffs on my 97 4r and had to use both 10mm and 12mm hex bits for the front fill and drain, so there's 2 more tools I need to add to mine. I usually carry a full socket set both 1/2 and 3/8, multiple extensions, a few screwdrivers, pliers and a crescent wrench. I would really like to get a cargo system built someday, until then its all in my hatch side compartment except the socket set.
Sorry to bring this back from the dead but i've searched and read what seems like 100 of these "tools, trail tools, off road tools, must have tools. ect ect" threads and this one on this site actually helped me out the most and i wanted to contribute so i figured i would contribute to this thread.
I made a little spreadsheet checklist of some of the basic tools that I plan on keeping in the 4Runner at all times. Not just off roading. This kit is very basic and i've used the info I acquired from this thread to put it together.
Now this does not include Recovery Gear, Survival Gear, or any Spare parts because that will be on another Checklist for either long highway trips or a specific Off Roading or Off roading/Camping checklist.
View attachment Tool Checklist 4Runner - Sheet1 (1).pdf
That is a PDF because I can't upload a spreadsheet file here.
If anyone has anything they would like to add to that or a better way of attaching this so that its editable (is that a word?) please let me know.
EDIT: Here is a link to a published google spreadsheet https://docs.google.com/spreadsheets/d/1tLxn7xrcrl6JX9HQkpHftOFNPQdRIxXYDVB9ebahap8/edit?usp=sharing
I like that google doc spreadsheet.
I would maybe add flare nut wrenches, but then I guess in the interests of avoiding 150lbs of unnecessary weight, you can usually get by with regular wrenches, vice grips, or pump pliars for flare nuts if you have to and if you're careful. Maybe not worth carting around special wrences 100% of the time, just so that .01% of the time one part of one job will be 50% easier.
Then again-again, clamping vice grips onto the outside of a flare nut wrench is pretty much the safets most bulletproof way to get an old flare nut free without destroying it, and that can be pretty important on that one bad day I guess.
I bring a 4 draw mini portable tool box I got from tractor supply. Probably no bigger then the bookbag ^. I have extra wire, solder, knifes, sockets, small hammer, Allen keys, wrenches, drawer just dedicated to electrical such as butt connectors, t-taps, fuses. Mostly anything you need. It's heav tool box. Does make noise but it's better to have it then not.
I pretty much keep my entire garage in my truck. I could do a motor swap. Just have to rig the winch over a tree branch.
Cpn2mss
