3rd Row Deleted! w/ pics and info (**Updates on page 3)
Any specific item you're unsure of?
I am having trouble finding the specific sizes for the screws, washers, etc.
Im working with a buddy on completing this mod and based off of the pics, we were unsure of what the m6/m10 materials were used for. We assumed the original bolts, from removing the 3rd row seats, are what were used in attaching the plywood to the frame but we could be wrong.
If memory serves me correct, I don't believe you are able to salvage the original bolts from the 3rd row seating for attaching the plywood to the frame as the bolts were too short. The new M6 bolts were for the "upper half" of the panel (nearest the middle row seats) and the new M10 were for the lower half of the panel (nearest the tailgate).
Still a work in progress and you are correct, I was unable to re-use the original bolts so i picked up the ones listed in your post. They seem to work perfect.
Curious as to how you handled the plastic clips holding down the rear light wiring. They seem to stick up a bit once the plywood is laid down. I was going to remove and tape down the wiring but wanted to get a second opinion. It also looks to me from you pictures you added an extra piece, in the rear, possibly covering where the wiring is ran or I may be seeing things. Curious as to what you did here.
Sorry for all the noob questions btw!
I think you're referring to the OEM scuff plate from a standard 2row 4runner. Check the parts list
i removed my third row too but kept the scuff plate and the side cover.. it looks raised to me but i think i like it raised. everything i put in there is contained. nothing is going to fall out when i open the back. just like in a minivan. see the video i created here. towards the end of the video, you'll see how it looks. i just installed back my cover. 2020 4Runner 3rd Row Seat Removal - step by step - YouTube
Thanks for this write up, very well done!
instead of making some covers for the 2 side compartment areas, did you look at a dealership for prices on new OEM 2nd row pieces? It may be a bit pricey. I'm a parts manager at a Honda dealership but the fella at the Toyota store gives me employee pricing, may not be too bad for me. I'm not even sure if swapping those two parts will work tho.
Much appreciated. I actually have looked into used panels and I found prices between $700 and $1000 for both. Not sure that I will make that sort of jump since the setup functions as needed. I'm sure I would if I came across them for a lower price. Can't imagine how much Toyota would charge for new.
ooph, ya thats high. Even with my discount it wouldn't be worth it. Thanks man.
Took the seats out over the weekend. Picking up the plywood & carpet this week. Looking forward to finishing this project.
Looks great. Wish I’d seen this post before scouring the country to find one without the 3rd row. Thanks for sharing.
Yeah, sadly I bought at the end of the model year and the only one around with the features and the color that I wanted I got stuck with the third row. I definitely hate carting around that extra 100 lbs of weight everywhere I go
There's not much out there for those DIY-types who are looking to take on the 3rd row delete. Google search upon Google search led to a lot of dead ends for this modification. The Goose Gear platform looks nice, but to me "unfinished." Not a knock to them, as it looks really well made. Google image searches ultimately led me to an Instagram user with a 4Runner. I reached out to him while he was in the middle of taking on his 3rd row delete. To my luck, he shared his CAD drawing WITH dimensions AND factory bolt locations.
A huge shout out goes to Rob for sharing his information with me. Give him a follow on Instagram @graphite_n_gasoline or @gus_the_4runner. Dude has awesome pictures and his attention to detail is top notch. With his permission, I will share some information for the DIY folks on here who need some guidance.
Reason for deleting my 3rd row:
-It's useless to me, as I have only used it about 3 times during my 2 year ownership.
-Weight savings. All removed items combined weight a boat load.
-It's not a permanent mod. If in the future I need to revert back, it can be done.
-Most importantly - more room! The 3rd row takes up a bunch of space.
My aim was to create an OEM feel. This involved utilizing carpet and creating "side plates" or covers. Lots of work to get this done, but I'm happy with the results. For those of you with 3rd rows and want to delete, it can be done!
You can YouTube or Google search how to remove the 3rd row seating itself. I took it a step further and removed the seat belt components.
Nearly everything can be found on Amazon or your local hardware store.
Materials needed:
-48 "x 48" x .75" thick MDO plywood or furniture grade (10 layer) Birch plywood. (I opted for Birch)
-4 x M6 rivnuts
-4 x M6 x 30mm long stainless socket head cap screw
-4 x .25 oversized stainless washer
-4 x M10 x 1.25 x .75mm long stainless hex head screw
-4 x M10 stainless washer
-OEM rear liftgate scuff plate for 2row equipped 4Runners
Optional:
-Roll-on or spray-on bedliner. Or carpeting of your choice. Highly advised to protect the wood surface. I opted for carpeting.
-Tie down hooks, or d-rings of some sort. I opted for US Cargo control L-tracks in black finish.
-I utilized t-nuts with flat head bolts from a local hardware store to bolt down the L-tracks. Not sure of the sizes unfortunately.
-Spray adhesive. I used 3M headliner spray to hold the carpeting down.
-1" door window hole plugs
-Sound deadener. I used FatMat
Tools used:
-Basic hand tool set
-Drill and impact
-Saw for cutting
-1" wood drilling bit, spade style
-Router
-Tape measure
-Beer (IPA)
Board with dimensions/measurements.
Before with 3rd row. (Mats are sold)
3rd row removed.
Progress. Ends were routed for the L-tracks. Bolt holes were made.
Carpet adhered to the platform and L-tracks are bolted down.
Installation complete.
Side cover shot. These weren't too fun to make as the 3rd row equipped 4Runners rear panels are sloped. I utilized some thin wood and covered with carpeting. They are held in place with small L-brackets bolted to an existing floor bolt hole.
Ugly cuts, but they're not viewable.
Another side shot. Used some 3M vinyl I had laying around to cover the seat belt guides.
This is Rob's take on making the sides by utilizing metal in lieu of wood.
Damn, seeing how much of a pain it is to get rid of the 3rd row makes me happy that I didn’t get it!
In my continuation to convert this thing to standard 2row, I finally bit the bullet and purchased the rear interior panels from a wrecked standard 2row 4Runner. The 3row panels were swapped out and happy to report that 2row panels swap right in without issue. I have also decided to make an entirely new cargo platform and will utilize 3 L-tracks instead of the previous 2. I will also be utilizing 4 bolt locations instead of the previous 6 as it was overkill. Below pics are the current progress.
The kennel for the husky fits perfectly between two tracks!
This is so amazing and motivated me to yank out my 3rd row. I got replacement side panels but non-3rd row have cutouts in the front of those panels (directly behind our second row) that we don’t have. One of the cutouts is apparently where the 2nd row locks in if you’d folded them down and then brought back up. How’d you deal with those? Just wondering how I might fill in/cover them up
2001ATL
