$40 homemade load bars, no factory rack
Fjatheart
Stainless hardware from Fastenal, rubber feet from hardware store. Super strut primed and painted satin black. Blue locktite on threads going into factory rack holes.
That's pretty clever. So if you remove the screw from the top plastic rail there is a threaded receiver there from the factory? I notice not many 3rd gens were sold as slick tops but mine is too.
That looks great. I'm interested in how you munted them to the roof. Looks like a factory accesory!!!
Thank you for the compliments. Im no master craftsman, but i wanted it to look clean and blend with vehicle. I looked at load bars out there and I couldn't justify the cost for as much as I would use them. Since selling my truck, I needed something I could throw wood and larger items on securely.
I simply replaced 4 of the metric bolts holding the rubber strip down to the roof with longer, stainless, hex head bolts/screws, I ordered off Fastenal. The bolts/screws go into the factory holes about an inch or better, so it's really secure. I put some blue locktite on the threads for good measure.
I got the rubber stoppers from a local hardware store and drilled holes through the center. They provide a solid foot and only cost about $3 each. Strut cost about $15 and I cut to 46 inch lengths. I didn't want too much of an overhang to catch anyone getting in and out of the car.
I wiped the strut down with acetone and primed it with adhesive promotor, then did about 5 coats of satin black Rustoleum.
If you guys decide to make one and have any questions about hardware or dimensions, feel free to give me a shout.
Nice idea. I added an extra factory crossbar to handle more load. I would suggest making your bars at least 50" long to handle sheets of plywood. You could flip the strut and recess the bolts and then you can put the hook in cam tie downs in the end hole of the struts and eliminate the eye bolts. Just a thought.
Still getting children in and out carseats, concerned I'll accidentally wack one on the head, that is why I went with shorter bars.
I've seen the strut turned with other side facing up and cam locks used. Those work well too.
How much clearance is there between the middle of the roof and the middle of the crossbar? Looks like they're almost touching in the pics but I know the angle is not good.
Would you please share which size bolts/screws you used? I might just do this mod this afternoon if you don't mind :biggrin2: I already have some aftermarket cross bars but they are tied down rather than bolted. I'd just have to drill a hole and find some sort of rubber spacer such as yours to separate the bar from the roof. Thanks in advanced.
I used 4 of the M6-1.0 x 75mm. I went with stainless to avoid the rust. I went with a socket head, so I could use an Allen wrench, but anything type head would work.
Be careful with drilling a hole. I simply removed a shorter factor screw and replaced it with the longer one listed about. I already have the holes/anchors for a factory rack in place, then I when above the factory rubber strip with the 1 inch rubber spacer. The super strut was about an inch thick and I screwed the 75mm screws in about an inch. If you flip the strut over, with the U facing up, you only need about a 55mm to 60mm length screw/bolt.
I'll say one thing....... thats a really cool looking paint color on your 4Runner, probably the best of all of them. :bigok:
Looks good and the price is certainly right. I like it!:thumb3:
It looks like its really close to the roof though but I guess another rubber bushing would solve that.
Thanks QJake,
I've got about a quarter of an inch clearance, but thinking about spacing it slight more, to account for deflection in the center. I'm concerned another complete spacer would be a bit wonky.
I post up with any changes.
Thanks QJake,
Agreed.
Maybe flip it over and use a couple of larger nuts or some stainless fender washers to space it. I'm thinking another inch higher should keep it from contacting the roof but that's up to you of course.
