450 watt margarita machine on inverter?
That's not good. Some appliances/tools, such as ones with a motor, require an initial surge of power to start up ("starting load" or "peak load"). Once started, the tool or appliance requires less power to continue to operate ("continuous load").
This is what you need...
My LE rear inverter is only 400 watts. My margarita machine has a 450 watt motor. Is it worth trying, or am I just going to be replacing a fuse if I do?
I doubt that it says in the manual how this machine uses 450 watts, maybe in reality it uses less than that and you might be fine. But I wouldn't plug it in because if fuse survives chances are that inverter gets too hot or motor won't get enough power and burns out prematurely.
I believe the "draw down" would depend on how jammed with ice it may be at the start. If you present a considerable initial load it may be problematic but keep it light and maybe try pulsing it initially.
If it were me and I had good Tequilla - I'd try it!
Assuming good tequilla, the outcome will be painless either way.
Start it empty, then pour what you need in. You'll probably be under 400. You can get a meter and test it, because what's on the data plate is usually just an estimate.
4Runna4Rumma
