4Runner Startup/Display Off Images
I redid my No_Heep image, and did a T4R.ORG Badge image
The No_Heep is included for your copying pleasure!
Created some images for mine, so I'd thought I'd share. Enjoy!
I just made this one for my 4R. BTW it works on a 2015 TEP as well. Settings -> General -> Customize Startup Screen. The rest is the same. Earlier posts indicated 2014 only.
Make sure the folder is in the root of the drive named
StartupImage (Case sensitive) and the file name is 8 characters or less (ASCII).
I put the usb in the dash port then started the 4R.
Does it matter if I'm using a MacBook to do this? I only have the pictures I want on there and I typed everything correctly case sensitive and all. I put the usb in and start the truck. I got to the right place to change it and when I click on transfer it can't connect. Tried for about 10 mins and gave up. It connected once but it couldn't find the images. I don't know what to do cause I'm following all the steps correctly.
Is it formatted FAT32? I'm not a MAC guy so I'm not familiar with how they would format a USB drive.
I updated it and now it's connecting but it says it can't find any images when there's pictures inside. All of tem are JPEG files. What else an I doing wrong?
Refer to post 44 for instructions found "In the Manual"!
Hope this helps
Good info. I had to select "transfer" a few times to get it to take, but it did. I used the same image (saved in two different folders) for my startup and off screens:
If anyone wants it, I took the shot so feel free to use it:
