4runner TRD Pro
What would be a fair price for our stock Nitto Terra 265/70/17 tires for a quick sale?
I'm getting BFG KO2 275/70/17 installed shortly :llama:
No clue on the Nitto's Value but I can tell you I love the BFG KO2 275 70 17. They are so much nicer then my old tires.
I have a 2016 PRO and took delivery with both driver and passenger sides displaying this half moon cut out. I don't think it's that big of a deal. If your reservoir was impacting that piece then perhaps it wasn't trimmed enough at the port?
Just took my 2017 TRD pro in the dealership on Wednesday. Driver side was not rubbing when I first got it. Hearing metal rub. Only have 500 miles on my truck. They notched the driver side out a little more and also took pictures to send in for Toyota to put out a bulletin on this issue.
Checking to see if anyone has light bar on there Pro behind the grille. There is a group buy going on with KC Hillites. This ones looks to be the easier one to install. Any reviews on this light bar. Thanks for any info.
<blockquote class="imgur-embed-pub" lang="en" data-id="a/FJdJf"><a href="//imgur.com/FJdJf"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
Just got this in Wednesday!
I am pretty sure with any of the light bars you will either have to make or buy brackets to to mount them. Most of the brackets are for 30" bars. For shorter bars you can drill into the bumper to mount. I don't have any experience with the kc lights but I did use Rago brackets to mount my bar and do like them.
Yeah, I had a Cali Led on my Tacoma and it was easy to install. The Cali one for the 4Runner you need to remove the front bumper. That ain’t happening. Lol. The KC hilites you just remove the plastic piece under the hood and reach down and put your two mounts and run you wire.
I was real nervous about pulling the bumper cover off but I must say, it was pretty quick and easy. I do understand not wanting to do it though but don't be afraid of it.
Agreed Rago install was painless!
2018 trd pro
Just got my 2018 TRD Pro delivered Saturday! Absolutely love it!
If anyone is interested .
I have a dealership that is selling a 2018 4 runner in white @ MSRP!
The vehicle is slated to be in on the 8th of this month.
It has cross bars, running boards ,cargo cover and exhaust tip.
MSRP is $45,112
3/8'' spacer in front lifting the front ~5/8'', 10mm spacer in rear lifting the rear ~3/8''.
If I were to do it again i would do 1/4'' spacer in front with the 10mm spacer in the rear... Or nothing at all. Really don't need to lift without wheel spacers(285/70).
Top plate or spring perch spacer up front. I did the latter and it's a bit nose high. I like the 10mm rear idea
3/8" spacer on top of the entire strut, using Wheeler's Superbumps with the front bumps spaced down 1/4".
I'd be tempted to swap out the rear 10mm spacers for Wheeler's T13 springs. I've heard of other only getting ~1" lift out of them, I like a little forward rake.
tuṣṭāva
