roof rails end caps are black, the bar between the caps actually looks dark grey. lower panel below the tail lights looks different or it could be me.
rear step is blacked out.
rear emblem & 4runner lettering surround is blacked out.
obvious replacement of the limited badge with raised TRD Pro lettering.
rims
Tail lights look like they are blacked out too.
Guys, I don't think we'd be seeing that much sand being thrown up if it wasn't supercharged..:behindsofa:
Check out the Grill you 2014ers & Headlights
Clearly from both pics, you can see more space between the tire and the fender well than stock. Using the 5.5" known from the wheel lugs I scaled the fender clearance at about 9.5". That's 3.5 inches higher than stock give or take allowing for error.
So we know there is a lift, we see the skids, it likely gets the TE treatment with Locker, crawl control and KDSS. It get a lot of blackout, badges, lights, wheels, exc..
So if a loaded 2014 TE with NAV and KDSS is about 40k (sticker) as the base for the TRD Pro...then you...
Add lift
Skids
Wheels
Tires
Is there enough room left to allow a supercharger? Without pushing this thing over 50k?
I don't think so...I don't believe you can put that much stuff into a package like this and make it affordable to the target group.
Knowing that everything I said is speculation, let's assume it is a decked out TE with the cosmetics we know of, lift, tires, wheels, skids and so on, and let's assume it also has a super charger......
How much would YOU pay for it?
For argument sakes, let's pretend you don't already have a T4R you are paying on, and you can afford a new vehicle..
Check out the top left. Looks like they're taking a hint from the FJ and throwing the old school "Toyota" emblem on it instead of the logo.
Doesn't look lifted from the back, also, why would they put cheap-o GrandTreks on a premium truck with a lift? If they want to lift it, and supercharge it, then why not go down the Raptor route and give it a wide body kit to match and some proper tires, not something you'll be taking down to Big O Tires the second you buy it... because if you charge Raptor desert truck cash, you want a Raptor desert truck.
Assuming it costs 50-55k, that's a lot for minor tweaks, and you're mostly playing for the blower.
Also, if Toyota does offer a "factory" lift, which aftermarket manufacturer would they go to? And if they would do that, could you just walk into your Toyota dealer and lift any 5th gen with that kit?
Really, we can't even get some BFGs?
GrandTreks?
You guys realized that all the blacked out bits (minus the blacked out rear bumper skid/trim thing) are all already there on the 2014 TEs right? :caked:
