4Runner V8
Hello guys, jus tan easy question on the 4Runner V8's I'm looking into getting rid of my V6 runner and purchasing a V8 ,just wondering how much difference the 2005 vvti engin would make , or would the 2003 thru 2004 be almost as good ,,
thanks
IMO the original T4R/GX V8 is plenty powerful. The GX (even with the older 235 hp non-VVTI engine) finished "on the podium" in the performance categories such as 0-60 and 1/4 mile in this old Car & Driver comparo from 2003:
http://www.caranddriver.com/compari...5-v-acura-mdx-v-lexus-gx470-v-vw-touareg.html
And while the detailed stat chart from the above article isn't reflected in the online version, I have the hard copy at home and if I recall correctly the GX actually finished in FIRST place for 0-30 accelaration, presumably due to it's excellent low end torque and gearing.
So if you see a nice older V8 T4R I wouldn't rule it out just because it doesn't have the newer VVTi version - you may be content with the older versions power.
can you elaborate on the differences between 04' and 05' V8's? I'm looking at a Sport 05' but test drove a 04' limited today. 04' has plenty of power, but I was not overwhelmed w/ the "I have to have it" feeling. The salesman was confident that the 04' and 05' both had VVTI, however I see he is wrong and thought that was the case.
Is there a noticeable difference in power?
How about VSC and Trac control in the two? I've read alot online, but still confused as to which years you can turn off and on. I know when the full time 4x4 center diff is locked VSC is off, just not sure if there's any difference in the two years other than HP. Thanks
There is a noticeable difference in power past 3k as the VVT-i really helps breathe life into the upper RPM ranges. You wont notice much at all down low.
My '03 Limited V8 has no VVT-i (Variable Valve Timing with Intelligence) so i don't have to worry about it. But i used to own a 2000 Celica GT-S which had the VVTL-i (Variable Valve Timing with Lift Intelligence), made 40hp difference with the GT model.
I have both the 2004 V8 4x4 and the 2008 V8 4x4. I don't see any noticeable difference in power or acceleration in everyday driving.
I also drive long distances and often have to pass big commercial trucks in Alaska. Both V8's have plenty of power, and again, no noticeable difference to me.
Power difference:
2003-2004 V8- 235 HP
2005 and up V8 270 HP
There were no change in VSC in early models, I believe the only one that have VSC manual off was 2009 model… and maybe 2008.
The 2004 V8 had less horse power but more torque. Here are the specs from Edmunds.com:
2004: V8- 235 HP / 320 lb-ft
2009: V8- 260 HP / 306 lb-ft
All things considered, the 2 versions are very similar.
The funny thing is that Edmunds.com also shows the 2005 V8 as having 270 HP / 320 lb-ft torque, but this must be a mistake because there are only 2 versions of the 4.7L V8 in the 4Runner.
I also heard that there was a change in the way the HP rating was done a few years ago, which may add to the confusion...
Thanks for the replies. I drove and bought an 05' today. Honestly can't tell much difference in the 04' I drove yesterday. But I had a salesman in w/ me yesterday and I didn't run the 04' limited very hard. I did however drive the crap out of my new 05' on the way home! Love it! Glad I went w/ the V8, but still not sure how the SUV will work out being used to a truck. I have a trailer for my wheeler, so I'm sure it'll be fine w/ some getting used to.
Thanks again. Good info here
You're correct. There were only two 4.7 V8's in the 4Runner, with VVT-i (2005-09) and without VVT-i (2003-04).
2003-04 V8 without VVT-i:
235 hp @ 4800rpm
320 lb-ft @ 3400rpm
2005 V8 with VVT-i under the old SAE testing procedures:
270 hp @ 5400rpm
330 lb-ft @ 3400rpm
2006-09 V8 with VVT-i under the new SAE J1349 standard:
260 hp @ 5400rpm
306lb-ft @ 3400rpm
For an apples to apples comparison, compare 2005 numbers to the 2003-04. It's the same engine in 2005 as it was in 2006-09, just how power was calculated and reported is done differently.
