4Running Daily's Build Thread
I commend your bravery in running bronze wheels. I am too scared to try new things =p
I am curious how much dampening your shocks are providing while they're leaking. My Icons showed no signs of leaks, I just had them rebuilt because I had the front rebuilt. I was, however, able to compress them by hand if used both hands on the top and had the bottom on the ground. I just tried that on a set of pretty fresh Radflo's and I could not budge them, even with all my weight on them. Makes me excited to get my shocks back and see how much they've changed.
On an unrelated note... Your shocks continue to blow my mind with those stickers. So weird. I had Icon send me some new ones to use on my freshly rebuilt shocks and they came in today. Free =D
When I put these Icons in I couldn't budge them. I had to use a ratchet strap to compress it to get it on. They aren't leaking terribly, but in a few weeks I'll pull them off and find out. They're still stiff as shit to drive on, I know that haha. Those stickers are less and less appealing the more I look at them, they'll come off when I rebuild them. Good to know I can go get free replacements.
Good idea. On the plus side, the bodies probably look minty fresh under the stickers.
Well what a day.
It started like this:
IMG_5105 by Connor Rhoades, on Flickr
Then this
IMG_5110 by Connor Rhoades, on Flickr
And then something interesting happened. Just like I thought, the tires don't clear Savage Sliders, but only on turns. So Discount helped me do a 10 point turn in their parking lot and wished me luck on my way home. It was an interesting drive, but now terrible. 4.10's and 35's aren't nearly as bad as everyone says.
My dog was pretty unsure of my decision, as was I.
IMG_5113 by Connor Rhoades, on Flickr
Savage Tire Carrier took it like a champ:
IMG_5118 by Connor Rhoades, on Flickr
uhhh
DSC_0001 by Connor Rhoades, on Flickr
They stick out only slightly, not terrible, but just one more thing I can be cited for
DSC_0011 by Connor Rhoades, on Flickr
So, first I started with what I thought would be the easy side, the back. It rubbed the front pinch weld while going over speed bumps. I taped off the area and took a sledge hammer to it. Sadly I found lots of bondo on one side from when it was repainted. This caused the body to chip slightly. So I taped it off again and put a little bedliner on the corners, almost like a rock guard. It turned out pretty good.
DSC_0015 by Connor Rhoades, on Flickr
DSC_0014 by Connor Rhoades, on Flickr
Sadly, there are plenty of other rubbing issues in the back. In this photo it's rubbing my rear bumper and the rear pinch weld, a problem easily solved on another day.
IMG_5126 by Connor Rhoades, on Flickr
IMG_5131 by Connor Rhoades, on Flickr
After cutting the slider about an inch or so on both sides, it's still clear a firewall tub is in the future. I rub the pinch just slightly under compression and turn.
IMG_5132 by Connor Rhoades, on Flickr
Overall I'm very happy with it. It looks fantastic and I can't wait to cut more and wheel the piss out of it.
IMG_5137 by Connor Rhoades, on Flickr
IMG_5134 by Connor Rhoades, on Flickr
I am with the dog as far as the being on the fence about the look, but as long as it has great utility off road, then so be it. If anything, at least the sniper has a bigger target next time around.
Any more pics of the Porsche? Nice 911 SC I take it.
It's actually a model newer than an SC, a 964. I'm currently in the process of installing Bilsteins and H&R springs. Working on the 4Runner is so much easier.
Untitled by Connor Rhoades, on Flickr
Thanks for posting the pics. Does it have the flat 6 or the turbo 3.3/3.6? No more torsion bars beginning here.
Kudos to you for doing the work sans some sort of lift. It would drive me crazy.
Looks like real fun.
3.6L flat six. It's annoying sometimes, but you learn to deal without it. One day in a house of my own, I will have a lift, it's a priority.
And while we're at it anyways, here's a pic of me Auto-Xing it
DSC_0406 by Connor Rhoades, on Flickr
