4Running Daily's Build Thread
Getting closer
I don't see any holes in the block. Excellent!
Must have been a fight to get out since I don't see the front tires on....
When I pulled mine it was a lot easier to go through the wheel well to get the exhaust apart right there. And also gave you decent access to the motor mount if I recall correctly.
Very nice. At least you will have a nice present to come back to from Alberta.
I guess you have never done the Tundra brake upgrade then? At least flush the brake fluid, its darker than the paint of your 4runner.
Keep an eye on the coolant level for awhile, and top-off as needed.
I can't believe you didn't take my suggestion. It could have been a lot of fun with 638 hp...
Will do. I have to go but some Toyota Red.
This engine has 97,000 miles btw, feels pretty good.
Whhhaaaaa, missed this quote... you still up in Banff?
It's gorgeous out there but a bit of a tourist trap. Your in Banff, Im in Texas! haha
Did you go to Calgary at all? Too bad I wasnt around we could have hit a trail!
Definitely a tourist trap, but a nice one. I'm back in Cali now for a month until I move to Arizona for school.
Good job, that is on washing the 4unner.
Definitely a Sun Devil come next month? I now know where to come to party when I fly to Phoenix in November.
Time for the real update:
Mileage of car on time of install: 177,152 miles
Mileage of Motor #2 on time of install 92,000 miles
New Toyota Genuine Parts:
-6 Rebuilt Injectors
-Water Pump
-Thermostat and Gasket
-Timing Belt
-2 Timing Belt Idler Bearings
-6 Spark Plugs
-2 Camshaft Seals
-2 Crankshaft Seals
-Oil Filter
-Release Bearing
-Valve Cover Seal Washer
-6 Spark Plug Seals
-2 Valve Cover Gaskets
-PCV Valve and Grommet
-3 Belts
-Oil Pan
Is this a DIY or will a shop be installing this? I have them linked so when mine goes out about 2020 I can order one.
Already have orientation @ ASU?
