nismojason
This is incredibly simple and I'm surprised that I haven't seen anyone post anything about it.
Anyway the quick and dirty: By adding washers under the front floor mounts for the seats, it tilts the seat back. This gives you more support under the front of your legs. It takes away the feeling of sitting "low" as so many people describe.
To do I put (5) 5/16" washers under each front bracket. Any small shim or washers will work. They just need a hole large enough to use the factory M10 bolts. Also because this moves the mounting hole slightly off center I loosened all the bolts for the seat, got each one started and then torqued them down. Do be careful not to crossthread your bolts.
Try it and let me know what you think. Seat comfort is one the few complaints I've had about the truck and because of this it could no longer even be a problem. Only thing I'm not sure about is if this will be better on the longer road trips.
Jason
Jason
