4th Gen Suspension Options/FAQ
THis would really help me figure out my 6112s i had installed last week. Can i ask what c-clip setting did you used and whats your hub to fender measurement?
Alright, to JRM and anyone else that is interested....
My setup is:
Tires: BFG K02 265/70/17 w/1.5" spacers.
Front: Icon UCA's with Delta Joints, Bilsteing 6112 coilovers set at the max setting.
Rear: Bilstein 5160 reservoir shocks, ARB 2" medium coils on a metaltech RAS to coil conversion kit.
My measurements after a few weeks of settling, and some rough offroading/crawling are: (ground to fender / hub to fender)
FR: 36.75" / 21.75"
FL: 36" / 21"
RR: 38.25" / 23.5"
RL: 38.25" / 23.5"
Now... I am planning .75" worth of spacer lift on the driver front, and .5" worth of spacer lift on the passenger front. This will bring it a bit closer to level. My CV angles look really good right now, so I don't think another inch or so of lift will hurt it. Does anyone have experience with spacers on lifted shocks? How was your downtravel after you did it?
So this is the set up I'm considering. 5100s on all 4 corners with the front set at 2.5 and 1.5 saw coils in the rear. I orginally was going to do 1.75 in the front with a 1" cornfed spacer in the rear, but do to hualing a 1100lb tear drop so I think I need the coils for the weight. Several questions:
1. Is this a good set up?
2. Bilstein makes an adjustable rear shock. Should I use those instead of the coils?
3. Suggestion on wheel size that could also fit the spare wheel well? I only want to go up to 31-32" tire size. I would like to keep the stock wheels but doesn't seem safe according to the tire size calculator.
4. I decided to go with those adjustments to keep a little rake and not look like the rear is dragging when I'm towing the camper.
Sent from my SM-N950U using Tapatalk
I just installed bilstein 6112 coilovers on my front end, and bilstein 5160 reservoir shocks on the rear with 2" lift medium duty coils. I love the set up, and think it would be great with what you are wanting.
That's exact what I'm about to do, super excited.
Sent from my SM-G892U using Tapatalk
Thanks man
FR: 36.75" / 21.75"
FL: 36" / 21"
RR: 38.25" / 23.5"
RL: 38.25" / 23.5"
Really helps.
My front end is @ 21.00 - 21.25" on both sides using c-clip settings 4 on the drivers side and 2 on the passenger side. It looks like its yielding the 2.1" of lift as per the instructions if i base this on a OE 18.75 to 19.00" height before install of the 6112s. I do have about an inch or more of rake as well
Im going to move the c-clips to 5 driver and 3 passenger to reach 2.5" up front so its more level and i gain back some of that entry angle i had before.
After doing a belstein 5100/FJ lift do you have to upgrade your sway bar links? And if so what ones did you get??
I'm getting some 2007 FJ rear links to match the rear FJ springs I'm installing. But what is everyone doing for there front links?
Sent from my SM-G892A using Tapatalk
I’m planning on taking out my front Bilstein 5100s and raising the circlip to a higher setting. Is this as simple as it looks? Just get the coil off and raise it?
Bump for answers or help. I'm also considering the nittos 285 70 17 on the stock wheels. Will this work?
Thanks for the great info, but I still have several questions if anyone can answer them.
  1. Why are lifts typically different between the front and back? Would this not un level the vehicle?
  2. Regarding FJ springs, the guide says they lift both the front and the back, but they always come in pairs of two. I’m guessing I need two sets for a total of 4 springs. Is this correct?
  3. Regarding Bilstein shocks, most people have theirs at .85” instead of 1.75”. Is there a reason for this?
  4. For my lift, I’m looking at getting Bilstein shocks, FJ springs, and new tires. I’ve read that people recommend getting these all done at once. Is there a reason for this outside of convenience?
The reason for the uneven lift amount front vs rear is to level out the vehicle and bring up the front to be more level with the rear. Most people hate the stock rake but do prefer to have some small degree of nose down rake. Yes, you’ll need to get a set of new front springs and a set of new rear springs to complete the transformation. I have heard that the rear Moog FJ springs are poo poo and that it’s become increasingly difficult to get a set of decent limited use FJ springs as well. If you are trying to level , I prefereably like the look of the 1.75 more but if you tow, the rear will get pulled down some so in that case I believe the .85 would work best...My idea on the “install everything at once scheme” is that so you do not have to go to a mechanic multiple times and you just get it all out of the way in a single day. This is whether you install the new parts yourself or go to someone either way.
Hope this helps!
Figured I would share my experience. I just had Wheelers T1 and T12 coils installed. I initially had Bilstein 5100s installed around a year ago with the stock springs (the clip to the first setting just about leveled it). I just had the springs installed and had them put the clip back to the original setting. This ended up raising the front 1.5", and the rear went up 2.5"!? I was expecting for a level stance but I guess I should/could have left clips where they were. Maybe the rear spring will settle some. *FYI those are 265/70s
How did everything end up settling out? I’m about to order a set I think but only if your rears settled more. Any pics within the past day or two?
So after all the reading I've done I think I'm only bumping the tire size up to a 265 70 17 from a 265 65 17. 275 70 17 is still in the mix but due to the lack of brands I may not opt for this size.
The biggest decision I'm struggling with is the lift. I'm without a doubt going with the Bilstein 5100 on all 4 corners.
I wanted to do 1.75 in the front with the shocks and add a 1" cornfed spacer to the rear. But if I ever wanted to go to a 17x8 wheel and jump up to a 285 tire I would not have enough clearance.
So the 2nd option would be to set the Bilsteins to the highest setting, 2.5 and add 1.5" saw coils in the rear, no spacers, so I would always have the option to move to a bigger wheel and tire.
I don't want to mod anything else if I don't have to. The tires I'm looking at are the Nitto tera grapplers, KO2, Faulkens, and General grabbers
Does anyone have one of these set ups or could provide some insight on which set up would work the best? I'f I do the 265 70 17 and I like the look and functionality I would most likely stick with them.
Fitting tires has little to do with lift amount, I fit 285/70/17's with only a leveling kit in the front. If you use up all of your travel/flex out occasionally the suspension still travels the same path whether you have a lift or not; you will have to do the same amount of trimming.
Trimming with the 285s correct? I havent read where there was a need to trim with the 265 70 17. I guess I'm just more looking for reason to do the 2.5" lift with coils vs. the 1.75" lift with a spacer in the rear. My thinking is the 2/1 lift will require more trimming if I bump up to a 275/70 or 285/70. This would be a correct assessment?
I had to trim with my 285s.
The trimming amount between 2/1 and 2.5/1.75 is minimal on the street, and there is no difference in trimming if you wheel your truck. Suspension lifts don't effect that, only body lifts.
So 2/1 or 2.5/1.5 is more for preference of look the function. I'm out on doing a body lift so I'll most likely stick to 265 70 or 275 70s. Thanks for the info.
Has anyone used the bilsteinlifts.com website before? They are not associated with Bilsteins but sell the shocks along with fox and toytec parts. Just wondering because there is no phone number to call, only email.
I asked a similar question and was warned not to use them. I forget the exact explanation but it was something about a sketchy seller who's made a lot of enemies on this site
seltzernator
