4th Gen Suspension Options/FAQ
Ah, ok! Sounds like my plan, haha. Got Bilsteins set at 1.75" being installed now. A word of warning...it's a pretty easy job unless your LCA bushings are seized, in which case it will be a long job if you want to replace them (which I am).
Hey mjotrainbrain, did you end up getting the 5100s done? Any pics? Happy with it? I still haven't pulled the trigger because I've been traveling with work a ton. But now I'm looking at probably doing the 5100s with the front set at 1.75 and installing the rear with the existing stock springs. Would love to know how it turned out for you.
I did actually get it done, and I've been very happy with it. It sits just about level to the eye, but by the tape measure the rear wheel well is about an inch higher. In any case, the running boards and windows are level, so it looks right which is what matters to me!
I don't 'have a picture on my laptop right now (I'll try to get one up this afternoon), but in the meantime I've got a handful on my Instagram @projectrustyrunner if you've got an account.
Ome lift question
Hey guys,
I am planning on installing the OME 2.5" lift early next year and was looking for input on the stone guards. Looking at buying the assembled struts here so i don't have to worry about builiding the front struts:
https://www.rocky-road.com/old-man-emu-4runner.html
My buddy has the same kit for a 5th gen and purchased the optional stone guards for extra protection of the rear mounts. It doesn't look like an option for the 4th. Didn't know if anyone knows if they will fit or has any other feedback, if they actually add protection etc
Hey guys,
It looks like they just clamp around the shock so I'm betting they will fit.
Since the shock shafts are on the top side on the OME shocks, I don't think the guards are necessary. They would only protect the bolt head from deforming against a rock or the rubber bushings from getting abraded (Rubber is pretty durable compared to the heim shocks), two things that aren't as big of a deal as a shock shaft getting pitted and wearing away the seals inside the shock.
But they are cheap and probably won't hurt anything.
Thanks for the feedback, that was what I was thinking. Seems like it just bolts onto the lower mount and would fit the 4th gen. Not sure how much protection it will really add but for an extra $30 seems like it would be worth it either way
Cheers!
Wondering if anyone is working with this setup
I’ve been trying to get a straight answer about the lift i’m planning for my ’06 sr5 4x4 V6 (no xreas). I just bought the vehicle and it appears to have a 2.5” spacer lift on the front which i’d like to get rid of.
My plan for the front is to use OME 2884’s with Bilstein 5100’s set to 0”.
On the back I would use Bilstein 5100’s as well, with OME 2895e’s.
My goal is to get a 2.5” lift in the front and 1.5” in the back. (this would maintain a slight front rake I believe)
I’m on a tight budget so I don’t want to upgrade the UCA's.
It is my daily driver, I live in a rural area, I tow occasionally, I camp a lot and travel on rough roads, but don’t do a lot of extreme off roading.
I’m running 265/70/r17 BFG Ko2’s and plan to keep this type of tire.
What lift measurements do you think this lift will yield and do you have any further recommendations?
I am new to this sort of thing, so i’m open to suggestions.
2.5/1.5 sounds reasonable, might be a little more with the old spring sag but it will be close.
Sway bar rub
Anyone have issues with the swaybar contacting the coil spring after installing Fox 2.0s? I've seen sway bar relocating brackets for some of the higher lifts, but never saw anyone needing it for just a level...
I just finished installing these on the front, and while checking things out after setting the front back on the ground I noticed the swaybar hitting the spring on both sides.
Maybe it's just how I had the sway bar set up when I put in new bushings, and it'll settle out of the way after I drive around a bit? Am I ok for a quick drive around the block to see, or could I really mess up a shock?
How much higher than stock are you? Don't guess, measure the distance from center of hub to the bottom of the fender.
Getting ready to get my OME lift installed on my 05. I bought the 1/4" spacer for the drivers side, will I need the extended lugs for it to install properly? Can you buy these lugs at lowes/home depot by chance?
I'm planning on picking up the Stage 2 Icon suspension (tubular UCA's) for my 06 sport on the Metaltech 20% off black Friday sale coming up. I've read that I will need longer rear brake lines. Metal tech reccomended this kit for $65.
:https://www.metaltech4x4.com/metal-tech-fj-cruiser-4runner-extended-rear-brake-lines/
My question is, is it worth getting just the rears, or should I go with a goodridge or crown kit that replaces all 6? And 2" is enough for a 3" icon lift??
goodridge kit:
https://autoplicity.com/3474725-goo...RiR8N-ePT8iEY9qhIygzmK5Bvxd9LqUvJsaAl0E8P8HAQ
Thanks for the help, new to trucks and want to make sure I do this right the first time around.
2003 limited v8 with Xreas
Can some one help me out and point me in the right direction I want to illuminate the Xreas do to the fact shocks are leaking out and go with the 5100s I would like to lift the rig and run 265/70/17 as my daily I would like to know what is a great setup and what else would I need and where can I locate all the parts I am new to all of this
http://www.toyota-4runner.org/4th-gen-t4rs/78803-compiled-fj-springs-lift-info-4th-gen.html
I did the FJ cruiser coils and 5100 shocks on mine and I’m really happy with it. Go through that thread and there is a lot of great information. You can do it yourself with basic tools and some YouTube videos
I was looking to move my 6112 clip up a notch. Can i do this while still mounted vehicle or would i have to take them off and disassemble them?
I just a little confused if i do it while still mounted it just compresses the spring more and staying the same height vs disassembling it and like reset the preload
Shocks have to removed and disassembled. Do not use those cheap spring compressors you can rent. Have a shop do it correctly or you could try the "no compressor" method if you know what you're doing.
