4th Gen TRD Pro Suspension Retrofit
Looking at picking up suspension PTR13-35140 of 2014 FJ. Thinking it should work similar to this build thread, but wondering if anyone has any recommendations for or against it.
Just picked up one of these with 8k kn them. Going on my gx is about a month. I paid $700 for reference.
Wanted to share my experience with the TRD Pro suspension in case others decide to pursue this option. I found the complete suspension including UCA's, rear arms, panhard locally for $1k off a 200mi 2016 TRD Pro. The modifications listed below are the only items I had to change, the TRD Specific part numbers are detailed as well. This is only intended as a reference document, I'm assuming you know how to install suspension, if not there are a number of forum threads and youtube how-to's available that cover that.
Donor Vehicle: 2016 4Runner TRD Pro
Recepient: 2008 4Runner SR5 V8 4WD
Difficulty: Moderate, suspension experience recommended.
Tools:
Large Impact (numerous bolts required this)
1/2" Drill or similar (or a hand file if you're patient enough)
Heavy Duty Floor Jack (I used 3.5 Ton)
Heavy Duty Jackstands
Small jacks - For misc lifting to position parts
Metric tool set - flex head ratchets recommended
Saw/Grinder or similar - For trimming the front shock eyes down
Hex Set - Required for remote reservoir and sway links
Required Modifications:
Rear shock upper mount hole:
Existing - 7/8"
Required - 1"
Front shock lower mount:
Existing - Too Narrow by about 1/8 - 1/16
Action - Trim sides of shock eyes
Parts Details:
UCA - Same as non Xreas
Rear Lower Links - Same
Rear Upper Links - Same fit, but thicker eyes
Panhard - Same fit, but thicker, tapered bar
Rear Springs - Slightly thicker, 1 additional coil
Left Front Shock PTR13-89160-LF
Left Front Spring PTR13-89150-AA
Right Front Shock PTR13-89160-RF
Right Front Spring PTR13-89150-AA
Left Rear Shock PTR13-89150-LR
Right Rear Shock PTR13-89150-RR
Ride Height @ fender lip after install: (if anyone has stock 08 4WD V8 height please share)
Front 35"
Rear 37"
Unfortunately I forgot to do before measurements so I don't have lift numbers.
The Parts
Note: I moved the front spring seats to the upper notch prior to install. Also didn't install the UCA's
Front Shock Comparison - A little taller
Rear Shock comparison - The TRD's are a bit taller
Front Shock Lower Mount Comparison - TRD is larger with thicker eyes
20161023_202208.jpg~original
Front Shock Lower Mount Comparison - TRD is 1/8" - 1/16" wider
20161023_202134.jpg~original
Rear Upper Links - TRD Eyes are thicker
20161023_111503.jpg~original
Rear Upper Shock Mount - TRD is much larger
20161022_104257.jpg~original
Rear Spring Comparison - TRD is slightly thicker and has 1 more coil
20161022_104643.jpg~original
Panhard comparison - TRD is more beefy
20161023_120033.jpg~original
Modifying Parts:
PLEASE NOTE! USING A 1" DRILL BIT TO WIDEN THIS HOLE CAN BE VERY DANGEROUS, USE CAUTION!!!!
Alternated between 1-1/8" step bit and 1" regular using light pressure so the bit didn't snag and break my wrist.
20161023_124827.jpg~original
20161023_124816.jpg~original
It fits! Also note the hole for the alignment tab and resevoir already existed.
20161022_104151.jpg~original
The front shock is too wide for the mount. I decided it would be better to trim the shock instead of the mount to retain the mounts original strength.
20161023_205043.jpg~original
Gently trim/grind back about 1/16" of material on each side. I tried a grinding wheel, but found the cutting blade in horizonal position worked best.
20161024_180302.jpg~original
Fits perfectly now. Be sure to alternate sides when trimming and ensure symmetry
20161024_182822.jpg~original
Ride height after completion and test drive. Will grab better shots later...
20161024_193345.jpg~original
Awesome post!
Thinking of picking up a set of TRD Pro take offs to retrofit on my 06 Sport V6. Though I may have to yank out the XREAS since I have the Sport model.
Mike
Just picked up a trd pro suspension kit (w/o rear springs)...can u guys recommend some rear springs that will complement the kit?
Stock 5th gen springs, trd springs, or aftermarket 5th gen rear springs?
I went with the Dobinson C59-505 and got 2.5 inches of lift. Basically kept my factory rake.
You can use that as a datapoint and go with something that gives more or less lift.
I just picked up a TRD Pro front suspension for my 4th gen. My current setup is FJ springs and shocks all around with the Daystar 2.5/1.5 spacer kit. Can I keep the daystar 2.5 spacer up front with the TRD suspension or will it be too high? If I take off the front spacer i'm afraid it wont be high enough. Any input appreciated.
What rear springs are you going with
I'm keeping the rear the exact same. Currently using Tokico springs and shocks from a 2013 FJ cruiser with the Daystar 1.5 spacer.
TRD Pro kit works on the 4th gen also. Very slight modification required. Lower bushing on the front shocks needs to be shaved down a hair and some people say the hole in the upper shock mount needs to be opened up slightly but otherwise it's bolt in and go. It lifts the 4th gen more than the 5th gen also right out of the box. Stock 5th gen front coilovers swapped into a 4th gen lifts the front about an inch so this should lift the front of a 4th gen about 1.5" - 2"
See post #1497 for reference
http://www.toyota-4runner.org/5th-g...ro-suspension-kit-sale-ptr13-35140-a-100.html
Can anyone with a 4th gen confirm if they netted 1.5-2” lift?
Thanks fellas!
Do the 5th gen TRD Pro UCA's fit the 4th gen (v8 xreas).
Lots of sellers including the UCA's.. most retrofit's are reusing the OEM 4th Gen UCA, and my OEM is probably worn at 190k miles.
5th gen upper control arms are a direct fit for the 4th gen. Many people are doing the same as you and using them to replace worn out 4th gen control arms.
These are the only two I've taken since I finished the project, will get it cleaned up and do some more one of these days. Don't have current/final measurements in front of me, but I recall it being just under 1" rake which put the running boards dead level.
Did u take these pics before or after the front 3/4” toytec spacer was installed?
Btw any tire rubbing with the spacer?
Thanks!
Hello, I just ordered the TRD pro suspension from a Toyota dealer and I was just wondering what I can get away without replacing until later. I see you mention some parts are same/same fit, does that mean that they do not need to be changed?
Thanks for the write up
I really don’t like having to drill that 1” hole to the upper mount. Is that front, rear or both?
utkrstam
