4th vs 5th gen wheel offset specs
nicheel8
Member
Anyone have or know where I can get the specs for 4th vs 5th Gen wheel specs?
I have an 04 2wd and I like the look negative offset look but I don't want to go the Spidertrax route. I need new tires soon and there are a lot of almost new 5th Gen wheels and tires on craigslist.
The Stock wheels on my 2011 SR5 were +12mm offset (17" x 7" wide).
Pretty sure the TE wheels were +15mm offset (17" x 7.5" wide) and the Limited wheels were +18mm offset (20" x 9").
I haven't kept up to date with the 2014+ models though, so not sure if anything has changed wheel-wise on the different trim levels.
I have been searching around for this info as well seeing I am looking to get some different wheels for my new SR5. Here is what I found:
Stock SR5 wheels: 17x7 with ET 12 or 15mm (most info points to 15mm so I am going with that for my research.)
Wheels I am considering:
- Trail Wheels: 17x7.5 with ET 15mm (these will have 6mm less clearance and stick out 6mm more than a 15mm sr5 wheel)
- TRD Pro Wheel: 17x7 with ET 4mm (these will have 11mm more clearance and stick out 11mm more than a 15mm sr5 wheel)
- FN Wheel: 17x8 ET 0mm (these will have 2mm more clearance and stick out 28mm more than a 15mm sr5 wheel)
not sure which way I will go.
Hopefully this helps others.
