4x4 PSA: Use it or lose it monthly reminder
Not sure why so many are having issues with the 4th gen 4 wd system. We might engaged our 4 hi 2 may be 3 times a year. I change the transfer case fluid once a year before snowboarding season and after 13 years and 275 k miles the 4wd has been rock solid.
Alright so my 2016 4Runner rear diff lock does this to me too. And it's been mine since brand new, only 27K odometer. What helps me a LOT with rear diff lock engagement is slightly turning the steering wheel while driving slowly in sort of a slalom maneuver back and forth about a 10 degree turning angle. So very little. And I can hear it click right into place by the second slalom every time.
What I accredit it to is that the rear axle shafts are not aligned TOGETHER for the locking sleeve to engage. So driving forward or backward perfectly straight does nothing since that keeps axles in the same position relative to each other. The slow slalom forces the axles to spin at slightly different speeds to each other allowing the splines of whatever sleeve needs to engage to line up correctly.
I would bet a center diff lock issue could be tested the same way but probably would need a more severe turning radius since those alignment shafts are for front and rear tire speeds, not side to side tire speeds.
4Reak Show-Worked like a charm!
Muuuuuuch appreciated!!! I tried the slight turning approach and it works every time, within maybe 5 to 10 feet. Friggin brilliant.
I know differentials as a general concept on paper but I've never pulled one apart (at least not a vehicle differential). I'm not familiar with the innards of the one on our 4Runners, but I think you are dead on about why this works; just need to get the two sides rotating at different speeds so the locking coupling/sleeve/spline/whatever has a chance to align.
Everything working pretty much like clockwork now in my 4WD system.
Cheers everyone....thread bump....Use Or Lose reminder.....
Do you guys exercise "all the buttons" or only the 4LO on the 4th Gen? DAC, Center diff lock, Traction control, RSCA off are the ones I have in mind.
I just do center diff lock and 4LO, but I think the biggest concern is 4LO since the 4wd actuator is what is prone to failure if you don't exercise it regularly.
I also don't have a traction control button - I think that was added in 2008.
Good to know! When I get my ‘03 this week I’ll set a reminder for myself on my phone, especially since I can’t remember shit like this
I thought mine worked when I purchased the vehicle a month ago but when I tried afterward, it would just blink. I could hear the actuator whine so I knew it was functional. I spent a little while tapping the actuator and transfer case while engaging 4Lo and it didn't seem to make much difference.
However, just drove down from Portland to Phoenix this last weekend and tried the 4Lo when I reached southern CA after 8 hours of driving and with 105 degree heat. It engaged almost immediately. Tested a couple more times just to be sure and now it seems to be working great. I'll be sure to exercise it monthly to keep it working!
Well, 4Lo is flashing at me today. Went for an overnight camping trip yesterday and 4Lo and center diff lock were working yesterday. This morning, they worked for a little bit and started having issues. So I put it back into 4Hi (V8 AWD) and about 30 minutes later, 4Lo started flashing at me and now won't turn off. Just got home and tried tapping the servo housing with a hammer but still no go. So now I get to trouble shoot and hope I can get the stupid thing working again. This has me ready to sell the 4runner. The tcase shifting is far too unreliable and an FJ case swap (manual shifting) runs about $2500 for parts alone. My 1999 Tacoma is far more reliable and capable off-road.
Fixed my transfer case. Installed a manually shifted FJ Cruiser tcase. Works so much better now. And it came out to around $1000 all said and done. $270 for the FJ tcase, $750 for the new driveshafts and I did all the work myself. Tcase is a direct bolt-in replacement. Cut a hole in the trans tunnel for the shifter, which requires welding to route it to the proper location and driveshafts get shortened in front and lengthened in rear.
my 4wd knob broke, have no clue why it broke, the cylindrical prtion that mates with the splines. any clue where i can buy a replacement knob?
