5100's set at .85, pictures
yotav8
For the price you really can't go wrong, they gave me just the right amount of lift and dampening.
Did ya get just the two up front or all four? How does the ride compare? I'm debating on the two shock vs. four shock kit.
Yup, I kept the rears stock, noticeably improved the ride comfort with minimal changes in the handling characteristics. Overall I am very impressed with the upgrade.
-My non scientific test involved driving slowly over a speed bump, OEM shocks would bottom out to the bump stops, 5100's hardly flinch.
I just did all four on mine and made a big improvement. I do not feel the bumps as much and there is far less noise.
I just can't tell the difference from stock. Are 4th gens noticeably front-high if you go to the next setting up; 1.75" or whatever?
If and when I pull the trigger on 4th gens, Bilsteins are likely gonna be purchase #1.
IMO the front as its sits is already higher than the rear at .85, at least for me 1.75 without any lift in the rear could look unbalanced
I put the FJ springs on mine along with the 5100's set to .85 and love it. It leveled it out the same as yours, but with just a little bit more lift at all 4 corners I think. Looks great.
Mine were set at .85 and honestly I cannot tell any difference in height or in handling when cornering. The only difference I see is a lot smoother going over bumps and a lot less noise. I replaced all four with Bilsteins and used the stock springs.
Mine were set at .85 and honestly I cannot tell any difference in height or in handling when cornering. The only difference I see is a lot smoother going over bumps and a lot less noise. I replaced all four with Bilsteins and used the stock springs.[/QUO
^my thoughts exactly, but the biggest improvement you will notice during daily driving is increased stability driving on uneven pavement or bad roads.
Is there any disadvantage to using the original springs when swapping the 5100's if you're not interested in lifting the truck? I'm guessing most people get the FJ coils because there is a slight lift associated with them, all I'm interested in is leveling the front and getting rid of my XREAS
charlesz
