5th Gen - Rear Wheel Well Parts
wheeldude
So I have been searching online for part numbers and haven't been able to turn up anything useful. I didn't notice until recently that there are covers and/or liners missing from my rear wheel wells. Here is a reference image:
y4m_Ry0-BMfCjmn0Bc-LOgXNTztALdMDHr6uv1MMW4WINvHbuSbo41RRMYWeh4KbOaVxsbYaUlzULojm_Mn4qFQQAFxHi9ZXN-_8e0skAGg5ng0rEbT9MIuKfpKsdqXbeXuANQo7uA6wQiHM2OGtKT4Mj3tG6MxJIgVIKDOWKK-wgBsmAYtB9hOojpZb3z7g6h8
In the image you can see where I have a cover on one side and not the other. For both side it appears that there were liners once there.
Thanks for any help in identifying these!
I don’t think you’re missing any parts, but there is a rubberized coating on the non plastic parts that appears to be worn away. Maybe look into getting them sprayed/coated especially if you live in a rust belt environment.
I've had to touch up the coating in my wheel wells a couple of times. A pressure washer (even with a light touch) seems to remove the color extremely easily. Not sure if it's just that thin or if it isn't adhered very well.
I've usually just touched it up with black paint, as the rubberized portion of the coating usually sticks around even after the color is lost.
The cover is for the fuel filler tube.
So I should not expect to see the same type of cover on the passenger side then?
Would be nice if one was there on the passenger side too, as it would help keep from mud collecting in the "valley" at the back of the wheel well!
erinobr2000
