5th gen tranny input/output shaft speed sensor
Chrisjamo
I have an issue with the shaft speed sensor not sure which one input or output. rodents chewed through the wires. My question is where do the cables go from the sensor. It is located on the driver side with green and white wires. Any help with location and wiring schematics would be greatly appreciated.
2010 4Runner Limited Trail edition
The one towards the front of the trans is the input sensor (turbine, NC0), the rear is the output sensor (SP2). Looks like it goes right to the main ECM (passenger side kick panel)
Also have the front sensor chewed off. Can anybody send a photo of where the wiring goes to from the sensor? Maybe the bundle above the trans? Only 8 inch section chewed off. New member can’t start a thread!! Thanks
Jhunt
