So I've read this thread as well as every other thread I could find on lifting and associated lean with KDSS. I have a stock, other than upgrading to KO2's in stock size, 2016 TE with KDSS and am looking to install 6112/5160 with the T13 springs sometime over the winter. Just measured my truck in the garage, with between 1/2 and 3/4 tank of gas, and my driver side sits 1/4 inch lower than the passenger side, both front and rear. My goal is to lift the rear approximately 1 1/2" and the front at least 2". I want some rake because I tow an Xventure XV-2 trailer off road on a regular basis all over Idaho, Oregon, Utah, and other western states. I currently have airbags installed to deal with the trailer weight, which have worked fantastic, and will probably install with the new springs as they aren't rated to handle much more weight than the stock springs. Anyway, I digress. Some posts have the 6112's at different settings to compensate for lean, but those posts aren't consistent, at least to my understanding, of which side is supposed to be compensated lower or higher. Other posts say have them on the same setting/"perch". Some posts have the OME or some other type of "shim" to deal with the lean issue. Some posts say the KDSS leans to the passenger side, but that's not how my truck currently sits. So, as you can see, for someone who is looking to do this in the not to distant future, it's a bit unclear of what, exactly, the proper setup should be. Maybe there isn't a correct setup as other posts I've read say each KDSS 4Runner reacts differently to a lift. So, given what I'm looking to do, any clear guidance on how I should move forward in the setup would be most appreciated!
