6112 / 5160 Combo with T13 springs - suggested setup
awesome! no lean from the 5/6 setting? I wonder if the more current 4Runners have an updated KDSS system that levels out? I set mine at the 7th notch and is even on both sides.
I need more lift. our trucks are too fat so even with the lift it looks short. hah
I have the same set up, and the difference/lean drove me nuts. The 5/6 notch thing that Bilstein recommends is for non-KDSS equipped vehicles to help offset the weight of the battery and fuel tank (drivers side). For KDSS equipped, you should have them set the same on both sides.
Total BS on the bilstein instructions, and I send them a note saying they should revise their instructions. Apparently it fell on deaf ears.
Bilstein is using my 4Runner for some development and outfitting it with the 6112/5160 combo. Mine has KDSS, and I've been told they're updating their install instructions for KDSS 4Runners. I'll try to post some pictures/info later tonight.
*edit*
Here's the lift at 2.9" front, 1" rear. They're still doing some fitments/measurements and will be putting in prototype springs that will bring the rear up 1.6". I'm planning to get some aftermarket UCAs, but they didn't have any issues with stock UCAs. Wheels: 17" SCS Matte Dark Bronze Stealth 6. Tires: 275/70/17 BFG KO2s.
*edit*
Here's the lift at 2.9" front, 1" rear. They're still doing some fitments/measurements and will be putting in prototype springs that will bring the rear up 1.6". I'm planning to get some aftermarket UCAs, but they didn't have any issues with stock UCAs. Wheels: 17" SCS Stealth 6. Tires: 275/70/17 BFG KO2s.
My hero
Just received my Bilstein 6112 / 5160 shocks, in addition to the Wheelers T13 springs. Wheelers assembled the 6112s for me at the #6 / #5 settings.
Based on what I have seen others do with their KDSS setup, I'm planning on installing the 6112s with #6 on passenger side and #5 on drivers. The Bilstein instructions indicate the reverse setup, but that appears to be for non-KDSS versions.
I'm hoping these settings give me the slight rake I am hoping for.
did wheelers charge for setting it up complete ready to go? i know you need new top mounts.
wheelers do charge to assemble the shock/spring & top mount. the price is around 70-100 i think but that includes the top mount as well.
A few notes from my 6112 / 5160 install:
1) I had to disconnect the tie rods as I didn't mess with the a-arm bolts. If I would have loosened the a-arms, I would probably have had plenty of room.
2) 5160 reservoir mount - my 4Runner didn't have a threaded hole as the instructions noted. I used a 1/4-20 rivet nut insert and was able to make it work.
3) 5160 washer install instructions seem backwards, but I installed per the pics. The curved section of the washer faces away from the rubber bushing instead of "around it" like other shocks I have installed.
4) Alignment: An off-road shop was able to obtain 3.4 caster on both sides, but then they said it pulled to one direction. They then backed the caster to 1.8 on left and 2.5 on right...tracks straight, but seems to be a little heavy on steering. They implied I should obtain new UCA so they can adjust up to 4. I didn't fully understand why they couldn't make it work as they where able to obtain decent caster numbers to begin with.
Better pick of my setup...had it on an easy trail today...checking bolts tomorrow.
Looking to run the 6112/5160/T13 setup, but I'm wondering what the overall height of your 4runner is after the lift is settled?
Any issues fitting in garages and parking decks?
Havnt seen any settling in mine after 3 weeks...still still at about 2.5" in front and 1" in back.
Not enough lift to impact garage parking.
Am happy so far...rides well. I was hoping for a bit more lift from the T13s though...was thinking of a trim packet on both sides, but don't know if it is worth the trouble.
My main goal was more lift for rocks though...front was too low. I wanted something a bit better than the 5100s, but wasn't willing to pay for fox or kings.
I'm currently debating if i should add the 1/4 or 1/2 + ext studs for an additional 1/2 to 1" lift. it was great at first but still feels a bit low to me. rides incredible though! hah. im hunting for 285 tires that should "lift" it another 1" or the appearance of. lol
Thank for this post it made the installation of the 5160 reservoir super easy.
Question the the people here who install the bilstein 6112/5160. I have a 2015 limited should I put 6 on passenger side and 5 at driver side or should I do the opposite? Thanks really appreciated. Oh I order bilstein 6112/5160 with wheeler t13..
I have KDSS and put passenger on 6, drivers on 5...worked for me.
Don’t know about Limiteds, but Wheelers recommended the opposite for SR5s.
Thanks I spoke with wheeler they say 6 driver and 5 passenger. I start working on my installation but I strip the uca nut.. I'm piss off but tomorrow is another day maybe I can get it loose..
Maxed out the fronts on both sides. Let's see how they look after they settle....
