86 Timing how to ?
B-27
I was wondering what the best way to time my 86 4runner was? I keep feeling like it's off and I'm just not pulling the power I used to before my engine swap.
You need a timing light to check/adjust your timing.
I dont think your loss of power is timing related. I would check compression and to a a tune up (ie, plugs, wires, cap rotor, fuel filter, air filter)
I have a timing light that I've used a couple times. I did the full tune up as soon as I installed the engine along with all new fluids ect. Is there somewhere I need to jump it to like in the V6?
Oh yes you do! I assumed you were already aware of that so I overlooked the obvious. I think in 1986 there is a connector on the drivers inner fender that you will need to jumper, if I'm mistaken on the year then you will need to jump terminals TE and E1 (hopefully I remember correct) on the diagnostic box behind the engine compartment fuse box.
Yeah, the changes came about in late 86 for the 87 models. your connector is going to be on the drivers side fender, it's the smaller of the 2 connectors over there. Here is a good link that covers most situations for the 22RE. you will have to scroll down a little to find what you want.
Toyota 4Runner and Pickup: Cheap Tricks
DionicioLives
