91 v6 has inconsistent idle....New to forum, new to toyota
taylz
This is my first toyota and so far I'm stoked....Only two issues so far!
Powertrain seems solid and it runs like a champ. I've been browsing some threads but I couldn't find anything specific to my particular symptoms.
Sometimes I get a randomly low idle at like 400, 500 rpms and it has stalled a couple times. (no codes, no check engine lights). Never stalls at lights when I'm driving. It's always on a fresh start usually after engine has warmed up then cooled a bit. Never happens when She's cold!...If I try and clear it out(rev it up) it doesn't help. I just have to get it in gear and get it moving for it to smooth out.....Secondly, is the starter.... I have to smack it with a metal rod from time to time. There seems to be alot of threads regarding this so I'm still researching previous posts(bear with me). Had it off and had a friend (whose a mechanic) take a look at it for me. when he opened it up it looks like the things brand new. No signs of wear at contact points on the outside as well....Once i put it back on it was great for about a week then started the same thing. Thanks for the help any input is greatly appreciated!!
I got the same issues with my '93 2nd gen v6 and have had it for 6 months now. In my case I will drive for about 30 minutes to an hour before getting to my destination. If I try starting it in less than 1 hour it will stall. After stallling I usually wait 30 to 45 minutes and it starts right back up. I can hear the fuel pump whining when I try starting it and can smell exhaust fumes so the fuel pump would'nt be the problem.
Thus far I have: flushed all fluids, changed the fuel filter, plugs/cap/wires, igniter (salvaged), rebuilt the starter,and changed the battery.
The previous owner swapped the engine out with a 95 motor but used a first gen distributor from an '89 or '90. I will be replacing the distributor this weekend from an actual 2nd gen and will be replacing a TPS and knock sensor as well, I will keep you posted for results.
....and the stalling is only at start up. It has never stalled while driving or idling at a traffic light.(knock on wood)
So I changed the distributor and my yota still stalls. I've checked for vacuum leaks and can't seem to find anything. Anyone with any ideas on what could cause this stalling issue???
DanielShawSZ
