94 4runner intake
josh terry
on my 2nd gen i took my intake off to replace vowel covers and plugs and wires but when i put it back on and everything on right my banjo hose were it bolts in to the intake it is leaking gas i need what should i do?
There are two thin washers that go on either side of the banjo fitting. Sounds like you may have dropped one and didn't realize it. Look around on top of the motor and see if its there.
i did drop one but got a different washer. i know i need a copper one but cant find one so i just used what i could find that would best fit it that wasnt copper could that have made its problem
Is that where it is leaking at? You can't just use "any" washer in it's place. Probably a dealer item... but you could search ebay or rockauto, etc.
They use copper there for a reason. I bet NAPA or the dealer will have replacements. If not, they normally come with a new fuel filter, and those aren't horribly expensive. :)
ok so I got the banjo hose fixed and got it to idol but when you put it into gear it won't pull me like it tries but can't and it has a rough idol I need the vaccum and gas line diagram can y'all help
