97 limited 4x4
4RunnerFlip
Hey everyone! Comin up on 320k miles on my babe and wondering what i should start to tackle/look out for considering it's got mostly oem parts throughout. Regular maintenence as far as fluids brakes timing belt spark plugs o2 sensors are being taken care of. But wondering if there are any particular parts i should be wary of in need of replacing. Put a new evap canister, intake hose, and fuel filter in so thats some of the things I've done. Any other reccomendations?
Be honest if check vacuum lines and just make sure u don’t need flushes( or tune, it’s getting up there so rings aren’t perfect anymore, sounds like u got it covered pretty good
New member but I have one about the milage you have. LBJs. T belt, water pump, radiator. CPS, CRPS, tbody cleaning, transmission drain and fill, diff fluid, transfer case fluid, check AC for proper charge. There is always something to be serviced on vehicles our age
Check compression. That will clue you in to other problems lurking. Send your oil to blackstone for analysis is another good one.
erinobr2000
