97 rebuild ------ will be asking for help
LRS23S
So i decided that i have the time to fix my old 4runner. What started out as a fender and door swap has turned into a what seems is a lot more.
My first question is what 02 sensors should i get I have a Magnaflow full sytem coming and would like to know what exactly upstream and downstream sensors i should be using with the supercharger or if that even matters.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
I am also in need of some way to repair my sterling wheel my Mel ripped off all the foam down tot he metal and was wondering if anyone is making a hard foam kit to replace it then ill cover it with leather or 550...
I also have a large order for SRQ parts. The first issue that i feel is gonna happen is the mounting plate that is welded on the frame rails for the bumper. They look like they are not gonna hold the weight. Should i cut them off and make my own mounting plates?
so got the Magnaflow system installed...you would think that they would include all of the needed bolts for connecting the exhaust system together but they dont. also the last hanger that has to be installed needs to be drilled into the frame for a proper placement. I am of course ok with doing the work but they should really update the data they have online. will post photos of the modification the last hanger when it stops raining and i can get out there again during day light. total time to install the system was about 1hr. aside from the hanger mod.
new carpet in for the most part waiting on second row clips for the seat back before finishing up.
[/IMG]
[/IMG]
[/url][/IMG]
I really need some help locating some roof rails to replace the stock OEM ones for the gobi rack. Anyone have any leads for something?!
Did you check Ebay?
If you can't find any for sale online my next recommendation would be to scavenge any Pick n Pull junkyards near you or a part out on marketplace or craigslist.
