99 4 runner headlight alert
your post makes limited sense; its like words are missing or something.
use the search function and if you still have a question then make it detailed enough so that we can answer.
headlight left on alert
Do you mean the left the lights on buzzer?
99's do not have such a buzzer
At least not any of the ones i have seen.
Headlights shut off once the key is out of the ignition
-James
As another James I second what the first James said--there is no chime--Thank you Toyota Gods, there already is an overabundance of useless noises:high5:.
They actually turn off when you open the driver door, and if they are left on the "on" position they will turn back on when the car is started. No chimes or noise
patnewton
