99 cargo cover
There's a little more to it than that if you want it to retract.
Yes it's easy to do, There is a spring in each end piece that has to be
wound in the right direction with the correct number of turns for each side.
As you disassemble it just pay attention you will understand how it works.
I did the same this year with mine, took 3 tries to get it right.
im currently rebuilding mine and like an amatuer did not count the amount of time needed to spring it back properly. Do you remember?
I want to say it was 4 turns per side. Keep in mind that it needs to be wound in the correct direction, depends which side end your working on if it's clockwise or counter.
seltzernator
