You struggling to let this thing go or something?
Me? No. I got tied up on Saturday with that wedding in Pittsburgh. I've PM'd you twice since then, haven't heard from you.
Also, MORE INFO:
In talking to people, here are few things I feel should be mentioned so that if you're considering my truck, you know them:
1.) At some point I am 99% sure it was at least painted if not hit and painted on the left side. The repair is very good, paint matches, no blend lines or tape marks but if you really look hard at it, there appears to have been a repair there. TITLE IS CLEAN!
2.) Dash clock doesn't work. But the head unit has a clock so it hasn't bothered me.
3.) NO RUST! I cleaned and painted the frame as a preventive step. I did not paint the skid plates though, planned to get them powder coated. They show some surface rust as any truck this age would but again, they're not rotted, damaged, etc. Same goes for the rim on the spare tire.
4.) The rear sway bar is pulled. With the lift, the sway bar was actually making it less stable. I pulled it and it drives much nicer. Sway bar is included with the sale and longer end links (stock 2nd Gen end links for example) would cure the stability issue.
