99 limited valve tick. where to go from here?
colorado4runnin
Hey guys, I have a 99 Limited t4r with the plain Jane 3.4L in it. I have just barley 201k on the clock, and it has a pretty loud valve tick on the driver side. My question is where do I go from here? It's really more annoying then anything, but I want to know some options I could have.
Do I just have a valve job done, if so how hard is it to do? And is it worth it because I've heard it could up my compression and throw a rod, so do I rebuild the whole motor? Or swap another 3.4 in it? I'm just lost and need some input.
Thanks guys!
Have you ruled out everything else? Failing injector, cracked exhaust manifold especially.
I have, I got in there with a stethoscope and listened to it and found it to be one of the two middle valves, it also changes with my rpm I forgot to mention that in my post...
Well I'm not sure what more to tell you other then if they do need a valve job (adjustment) I think from what I have gathered, you can just find the right size shim you need for your valves and replace it, (shim and bucket design).
There is a write up on Yotatech but I can't figure out how to copy and paste it here off my phone. I just googled 5vz-fe valve shim and it was the first link. Hope this helps.
Deelock
