307Vintage
Member
I just finished the Timmy The Tool man flush I’m my power steering system. What a difference! Wow. That was long over due.
Sounds like wrong belt then, too long, get a shorter belt.....or the tensioner is incorrect/wrong length bolts or something. Its pretty simple, all the belt tensioners are simple, and your mechanic should have been able to remedy it instead of sending you away not fixed.So I went back to the shop and apparently it's the pulley/tensioner on the left side by the alternator? Just looks like a bolt and slider system but it's maxed. which he says is maxed yet there is still slack in the belts.
Does anyone have an idea how to correct the screech? Anyone close by that could help me in any way - refer to mechanic, fix it for $$ or beer?
Should I try going to Toyota service (I know stop laughing).
I hate that trying to do maintenance it seems worse than not doing it at all.
And now on to that tail light issue...
Alternator belt is @ 1065mm and Power steering belt is @ 1085mm so they are easily installed in wrong spot, as dogtail said it should have been fixed.
