99 SR5 turn signals just quit working
Silverc4s
Very weird. They were always okay, then just stopped working halfway tru a road trip. Emergency flashers still work fine, fuses and flasher relay are good. Both systems use the one flasher right?
Anybody ever seen this happen? Is the turn signal lever/switch bad? Do these just fail? How hard to remove & replace?
Sorry for all the dumb questions,
Bill
EDIT: I was able to try a good turn signal switch and it still did not work! I am out of ideas. HELP!
See if any of this helps. Fortunately when it happened to me it was just the hazard button being a little loose. Pushed it back in and that fixed the problem.
http://www.toyota-4runner.org/3rd-gen-t4rs/83114-turn-signals-out-98-toyota-4runner-not-fuse.html
Edit: make sure that all of your fuses and relays are pushed in all the way and try using a multi meter to test the wiring itself. I just re read your post and I'm not sure the link I provided will be much help. Good luck and keep us posted.
