traben27
I finally got all of the parts and replaced the worn out original suspension at 215k miles.
Components
FRONT:
Coils - Used 99 Tall Coils (unsure of mileage)
Struts - Bilstein 5100 for 96-02 4Runner - Set up 1 clip - 24-248730
REAR:
Coils - Old Man Emu 906
Shocks - Bilstein 5100 for 96-02 4Runner - 24-249966
Reasoning
1. Mild lift - No need to go bigger than necessary for my use case. Don't want bigger tires (265/75s). Don't want to have to replace/modify anything else.
2. Higher spring rate - I liked the higher spring rate of the 906 vs the 890. I don't have a truck, so I use this to haul dirt, wood, anything I can't fit inside.
3. 4Runner Specific Valving - The shocks/struts are valved for the vehicle and not for a truck, so in theory it should be less harsh. Bilstein actually recommends a rear spring rate of 220# with these so the 906s are a perfect match.
Measurements
These were taken in approximately the same spot on my not completely level driveway. First is ground to fender, then hub to fender.
Before:
Driver Front - 35.5" / 21"
Driver Rear - 35.5" / 21"
Passenger Front - 35.625" / 21.125"
Passenger Rear - 35.375" / 20.875"
After (Pre-Alignment):
Driver Front - 36.75" / 22.25"
Driver Rear - 37.125" / 22.625"
Passenger Front - 36.875" / 22.375"
Passenger Rear - 36.875" / 22.375"
Result/Impressions
Lift:
I gained about 1.5-1.75" of lift which is exactly what I was looking for. The front is a tad higher than I'd like right now, but I'm guessing it'll come down a little after getting it aligned. If not, I'll probably take the front strut down to the bottom ring once the rears are fully settled.
Driving:
On road, the driving experience has improved dramatically. It leans less in corners, the front barely dives when braking, it handles pot holes, bumpy roads, and abrupt driveway/road entrances without being bouncy or jolting. I don't know that "drives like a truck" is a fair statement, as most people associate that with an acceptably harsh ride, so I'll say it drives like a "new, mid-size" truck.
My offroad impressions are very limited right now. I took it on a very eroded (sections are impassable without high clearance vehicles) dirt road near my home and it handled the bumps, holes, and climbs great. It's just more comfortable to drive overall.
Pictures
Before:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/65975175@N07/36271041416/in/dateposted-public/" title="IMG_5347"><img src="https://farm5.staticflickr.com/4298/36271041416_936d5f7df1_z.jpg" width="640" height="480" alt="IMG_5347"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
After:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/65975175@N07/35918653640/in/dateposted-public/" title="IMG_8418"><img src="https://farm5.staticflickr.com/4303/35918653640_d112a7c259_z.jpg" width="640" height="480" alt="IMG_8418"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/65975175@N07/35505625203/in/dateposted-public/" title="37204118-956F-4977-B8DA-7C1DC7A78ECA"><img src="https://farm5.staticflickr.com/4314/35505625203_0156c435fb_z.jpg" width="640" height="640" alt="37204118-956F-4977-B8DA-7C1DC7A78ECA"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Components
FRONT:
REAR:
Reasoning
Measurements
Before:
Result/Impressions
Lift:
Driving:
Pictures
Before:
After:
