994runner build
So i guess i will post up my bumper build here in my build hahaha i decided to go with the Ooutdoor Logic bumper since not many of us have them and it look pre good o start with!!
a lil preview of what it will look like!!
the final cut
while the bumper was removed i redone my grill
now there is a lil bit of test fitting to make sure it fits well
Now off To the powder coating and to who i took it too you may ask?? it is Rite Way fencing / powdercoating and i do recommend them they are faster than calgary powder coating or top gun and no 1-2 week wait i had my bumper back in 3 days there just by barlow and glenmore!!
and the finished product all powdercoated and mounted!! with the 10000 lbs Super winch!!
THANKS ERVIN FOR LETTING ME USE YOUR IDEA FOR THE BUMPER!!! I THINK IT TURNED OUT VERYNICE!!
Pictures001_zps096f722a.jpg~original
Did you use different led turns or the ones that came with the bumper?
amazing custom build!
Alright here is a lil bit of my rack light build still not finished but getting there first of all imma thank redsonja (james) for all the welding!!
since i will never shorten my rack i decided to have it welded together
IMG-20130108-00712.jpg~original
IMG-20130108-00713.jpg~original
flexingout023.jpg~original
flexingout027.jpg~original
flexingout035.jpg~original
flexingout037.jpg~original
flexingout041.jpg~original
after alot of grinding and sanding it was time to prime it and get her ready for paint i was not too picky about it being perfect
IMG-20130115-00727.jpg~original
IMG-20130115-00731.jpg~original
IMG-20130115-00730.jpg~original
IMG-20130115-00726.jpg~original
while i had the primer drying i went out and bought some L bracket cut them up and paint aswell
IMG-20130117-00736.jpg~original
IMG-20130117-00738.jpg~original
IMG-20130117-00739.jpg~original
next was to paint the whole rack before i just used a scotch brite pad and scuffed the surface so the paint will be all even and not original rola black and the new flat black the paint i used was a flat black by tremclad hopefully it will with stand alot of abuse
IMG-20130115-00733.jpg~original
IMG-20130115-00734.jpg~original
as you can see i just re used the old mounts
IMG-20130117-00741.jpg~original
IMG-20130117-00742.jpg~original
IMG-20130117-00740.jpg~original
IMG-20130117-00743.jpg~original
Now it is the part i will hate the most is doing a wiring harness the front bar will be controlled by a switch same with the side ones and the rear i was just thinking to wire it up to the reverse lights that's the only time i will ever use them
the way you mounted that to the factory rails is awesome!!
i like how it sits lower to the roof. what did you use to fit/make those custom brackets inside the railing where the factory cross bars slide in????
Digging the build so far. Just a thought, I think that sr5 badge would look a lot better if you put it on the bottom right corner.
Tailgaters??
ghengiskhan
