A/C blowing warm air
I've located the small vents cut into the plastic trim, and as far as removing that panel, is there a guide or a how-to video I can see to check if the sensor is plugged in?
Not having much luck between google and youtube in locating one...
Air mix servo motor
Try taking out the air servo motor box and rotating the white gear 180 degrees. This helped me to get hot and cold air back. The problem was that the gear was striped.
alexaturner
