Although I believe that some people have seal failures within a year of doing the replacement and have to do it all over again, what we don't know is if their truck is somehow out-of-spec or if the install was simply botched.
Look, isnt the story always "your axle must be bent" when the shop cant get the seals to hold? Right? How many runner owners would know the difference? How many people have sold their trucks because of the failed axle seals and just gave up? And do we really believe that our axle are so easily bent as the shops would have us believe. The most durable truck on the market has the most fragile axles. Yea right!
I just posted a cut away of the seals. You can clearly see where the lip sits. Yet I get pushback. If I had a spare axle housing I would do a cut away of that as well but I dont. So its time you do a little work to prove me wrong instead of attacking me. And to BFD, what makes you think I need your blessing on any of this? I just asked you to Go Away. Please dont come back.
It would be nice to hear from someone who runs a mechanic shop or works at a dealer as shop foreman.
The good shops have known this problem exists and because of the likelihood that any shade tree mechanic who probably wont measure their parts will have a failed repair, why would they make it public? They essentially become the expert in their town with a monopoly on the repair. Put it this way. If my income depended on getting $1200 for 45 minute repair, you can be damn sure I wouldnt be here telling everyone about it. You wont get any toyota mechanics to chime in here for two reasons. First, they would have to admit there is a problem which would be bad for their employer. Second, it would take food out of their mouth.
Actually, I remember a shop foreman from a Toyota shop that did say they had issues and they would have to seat the seal less deep just to get it onto the retainer. I quoted him in BFDs thread. I will track it down and repost it.
Edit: found the thread.
rear-axel-seal-leaking-3rd-gen-4runner
Quote: "Its been a while since I worked at the dealer, but when I was there we replaced axle seals on almost every Sequoia and 4runner in our area. The inner seal would leak and the rear shoes would become saturated in gear oil. Worst I have seen was a locked up wheel because of the brakes swelling up due to saturated linings. Finally Tech support started helping us out a little by asking us not to install new seals flush against the inner axle housing. We were told the seal itself was not at fault, but the metal ring which resides behind the ABS ring was not properly placed on the axle itself. Engineering flaw. The outer ring on the axle is what the seal rides against. We would apply a light coat of white lithum grease to the axle ring and reinstall the axle into the housing then spin the axle one or two times. Then carefully removing the axle you could see where the seal had been riding on the axle ring, if at all. We would take a measurement with a dial caliper of where the seal was originally and where it needed to be. Removed the old seal and replaced the new one further forward from the old seal by the measurment taken. Sounds like a pain and it was, hopefully they have modified the seal to correct the problem, but if not try to do this if your truck is out of warranty.
This is only in reference to 3rd gens. Like I said it's been years, going on four since I worked at the dealer. They may have a TSB out on a new seal design or axle ring. I just don't know. Someone on here I am sure works at a dealer now and can look into this or knows what I am talking about. But if your seal is leaking and its a 3rd gen then it will probably be affected like the rest of them. My dealer charged 3 hours a side to replace the seals, a half hour to R&R the diff fluid, 1.6 hours to replace the rear shoes and machine the drums plus the cost of the seals, fluid, shoes and brake cleaner. Not a cheap job when your out of warranty. Oh $89 per hour in NC. "
