about to purchase avic d3 need, have question about trim kit
Salsa, sorry but the Metra trim kit doesn't fit...the trim around the stock radio is moulded to the console and cannot be removed...i guess the JBL system has a slightly different opening even though the console looks exactly the same.
dvbennet - I was afraid that something like that may be the case. I really do not like the option (2 side peces) so I may have to try to make one myself.
Did you happen to take any pictures of the parts - where they fit and where they don't?
Thanks!
sory, didn't take a pic...the kit from Metra is shaped exactly like the trim around the stock radio...the problem is that the trim around the stock radio is actually part of the console...except it's painted black and the console is painted silver....there's no way you could actually cut it off without screwing up the console. I guess the 2-piece kit might be the only way to go at this point....then replace it when Metra makes a kit to fit our opening.
Where did you buy the wiring harness ? Do you have a part number ? Are there wiring instructions with the harness ?
I'm gonna do the install myself...i already took out the stock radio and inserted the AVIC...there's only a minimal gap above and below the AVIC...looks ok, so i guess the 2-piece trim will be ok for now.
Thanks for trying the install and providing the details. You certainly helped me out.
The wiring harness that I used also came from Metra (No. 80-1761). It says that it is for "87 and up" Toyotas. I am not sure that the dimmer is working 100% correctly (it will dim when the head lights are turned on, but will not adjust with the vehicle dimmer), but all else works great with this adapter. I picked it up at Circuit City.
Good luck with the rest of the install.
I was in a Target parking lot tonite and saw a 4Runner Limited...looks like it had the JBL stereo...this stereo is bigger than our stock radio but looks similar and it covers the entire opening...our radio is smaller and that's probably why they moulded the trim to the console...the rest of the console is exactly the same. Perhaps one of you guys would like to try and remove the "moulded" trim :)
Picked up the wiring harness and IPod cable...will start the wiring install next week...once that's done, i'll decide what to do about the trim.
dvbennet said:
Did you guys just twist the wires together (with electrical tape) or did you buy connectors ?
Twisting them together with electrical tape will almost guarantee a poor connection and you'll most likely have to reconnect the wires again.
The best option would be solder the wires together and then use heat shrink tubing (preferred), if not then tape the soldering with electrical tape.
A less preferred method typically used because it's fast and easy, would be using butt or crimp connectors. Using this method, you will still have a solid connection over twisting the wires together.
