ABS Light on - code 23
Downeys4Runner
Okay so I am trying to get the truck safetied and on the road. But, the abs light is on and it needs to be fixed. So I used the diagnostics on the drivers side of the engine. It read code 23 (two blinks - pause - three blinks), searching that code I got 23 - OPEN OR SHORT IN 3-WAY SOLENOID FOR RIGHT REAR WHEEL OR DEFECTIVE ABS ACTUATOR.
That means i need to check the right rear ohms off of the Right rear ABS sensor. But I have already checked the ohms on the driver side front and it doesn't read any resistance either.
I'm confused. Would the ABS light read 2 Codes if the Driver Side Front doesn't work as well as the code 23. :mad2:
patnewton
