ABS light on
97Toy
My abs light is on and the abs will engage at slow speeds. I have been looking around on this thing and I cant come up with anything. I have found that there are no codes in the system. help please.:help:
In my toyo exerience, the abs lite on = no abs. Check the connections under the seat and dash related to abs. See the FSM for a schematic. :cowboy:
When you say it will "engage at slow speeds" what exactly is happening? Can you hear it as you're braking, or is it actually braking for you?
My initial thought would be a bad wheel speed sensor. I'm not sure a typical code reader will read the ABS codes like it does OBDII codes.
The Youtube was for a 98 4Runner which I would think would have matched a 96.
I would think so, too. I did just like the vid and got a code. I used the second link to clear the ABS light. I'm sorry, but you've exhausted my knowledge on the topic. I have no idea what would make the other lights flash.
When you jumpered the connections, did you look at the schematic in the flipped over cap to make sure you got the pins right?
AndiGarage
