AC bulb question
Bigmd
Hey guys trying to get my 4runner interior in order. I've searched this but cannot find the answer. On my 2002 4runner the fan speed knob is dark with lights on. The temp indicator and vent indicator knobs are lit. Is it supposed to be like that or should the fan speed be lit up too. Thanks in advance
Should light up. The bulb you're looking for should be NEO4-w. It's the same as the ones in my 01.
It's a good idea to go ahead and replace all of them while you've got it apart - the others will go out eventually.
I sourced my AC dash bulb at Batteries Plus if you want to shop local and use the same incandescent as OEM. Also, there is a green rubber cap on the bulb that gives it the green hue. Be sure to get that off the burnt out bulb and put it on the new one so the light stays green. It helps to slightly wet it when you remove it so it slides off.
increasedc
