AC compressor wire cut
LedFloyd900
Rebuilding my engine and come across this...anyone know where this is supposed to go?
If you have a 22RE, the other end is a single wire coming from the main harness near the battery. Black with a blue tracer if I remember correctly--not 100% on that.
Probably broken, not cut. It is a frail, thin gauge piece of wire and easy to forget to disconnect when motor pulling.
Just looked in the manual for the wiring diagram, it says clutch is:
B-W(22R)
L-B (22RE/RTE)
I believe "L" is bLue, and B should be Black, so yes, it should be black with blue stripe!
Sorry, forgot to specify the engine. It's a 3VZE. Gonna run by salvage yard today and see if I can get another one to just splice in to my harness
If you dont find one i probably have one i can mail out to you let me know
I couldn't get the whole wire so I just cut the connections off and was going to get some new wire and basically make a new one but if you have the whole wire that'd be even better
I have a whole extra wiring harness for a 2nd gen post 93 3.0 Can you send me a pic of the connectors and ill go check it out tomorrow when its light out. It gets dark like 30 mins after i get home. I may have one on my parts truck but i know for sure i have one on my other runner that was my daily. Im going to small block it so i wont be needing the harness anymore.
Well after a closer look I may be able to just put a new connector on my harness wire pretty easy, but I'll let you know for sure. I appreciate it
No problem let me know. I know i should have it. Couldn't check had some stuff come up but i know its there
Mike Sargent
