AC Problems
dezrtdwelr
HELP! Its getting hot here in the desert. my 97 4runner AC started blowing warm air. At first intermittently and now all the time The compressor kicks on so with 245K miles I figured it was time for an evac and recharge. That worked for a few miles but is blowing warm again. I checked the high and low operating pressures after the recharge and got 270 and 3 psi. I have a sniffer but found no leaks. So do I need a new compressor or ???:confused:
In my opinion your compressor getting warm or compressor have expired so you need to check the wiring and might be any pipe leakage. I will suggest to go nearest car care center to fix the issue. I hope you will get the best advice.
chasebradshaw
