AC System O-Rings
dixie_boysles
So I just replaced my A/C condenser with a new one and I replaced the (2) fitting's o-rings. Are there any other o-rings I should go ahead and replace before pressure checking the system. I definitely have a leak tried to pull a vacuum on it and could not get it to. So today, we are going to pressure check it.
Usually you can actually buy a AC O ring kit for the vehicle. There will also be seals at the condenser that are common to leak over time.
Once you find the leak, and are ready to put it all back together, you should consider replacing the AC drier to help protect your new compressor.
Jhunt
