AC Vent location?
vegask
Member
So I feel worthless, I was under my 2005 V8 for 30 minutes last night with a flash light trying to locate the AC drip line and could not find it. Anyone have a picture or description of where it should be?
Thanks in advance.
Thanks in advance.
On 4TH Gens T4Rs the AC drip drain/tube is on the passenger's side directly above the frame rail next to the firewall, when the AC condensation drips out it will land on top of the frame rail, many times some will have rust issues in that location, to avoid the possible rust issue many will extend the drain tube so it doesn't drip onto the frame.
Yes, what AuSeeker says times two! I had a huge rusted out hole on the bottom of my frame rail under passenger side door where the drip would stop and then drip on ground. Cost me $1000 to have it weld-plated. The same area under driver door is fine.
I relocated the drain out to the wheel well and you should too.
Ambrose67
